Gaussian Random Routines
JohnNichols
Honored Contributor I
Some of the routines called in this sample are not in the documentation that I can find, CHECKVSLERROR as an example. Any ideas where I find details.
John
! Copyright 2003-2016 Intel Corporation All Rights Reserved.
! The source code,  information  and material  ("Material") contained  herein is
! owned by Intel Corporation or its  suppliers or licensors,  and  title to such
! Material remains with Intel  Corporation or its  suppliers or  licensors.  The
! Material  contains  proprietary  information  of  Intel or  its suppliers  and
! licensors.  The Material is protected by  worldwide copyright  laws and treaty
! provisions.  No part  of  the  Material   may  be  used,  copied,  reproduced,
! modified, published,  uploaded, posted, transmitted,  distributed or disclosed
! in any way without Intel's prior express written permission.  No license under
! any patent,  copyright or other  intellectual property rights  in the Material
! is granted to  or  conferred  upon  you,  either   expressly,  by implication,
! inducement,  estoppel  or  otherwise.  Any  license   under such  intellectual
! property rights must be express and approved by Intel in writing.
! Unless otherwise agreed by Intel in writing,  you may not remove or alter this
! notice or  any  other  notice   embedded  in  Materials  by  Intel  or Intel's
! suppliers or licensors in any way.
!  Content:
!    vdRngGaussianMV  Example Program Text
      include 'mkl_vsl.f90'
      include "errcheck.inc"
      include "statcheck.inc"
      program MKL_VSL_TEST
      USE MKL_VSL_TYPE
      USE MKL_VSL
      integer(kind=4) i
      integer(kind=4) errcode
      integer(kind=4) nn
      integer ndim,info
      integer n
      parameter(n=1000,nn=1000,ndim=3)
      integer brng,method,seed
      integer me
      real(kind=8) c(ndim,ndim),t(ndim,ndim),a(ndim)
      real(kind=8) r(ndim,n)
      real(kind=8) dbS(ndim),dbS2(ndim),dbMean(ndim),dbVar(ndim)
      real(kind=8) dbCovXY,dbCovXZ,dbCovYZ
      real(kind=8) S(ndim),D2(ndim),Q(ndim)
      real(kind=8) DeltaM(ndim),DeltaD(ndim)
      TYPE (VSL_STREAM_STATE) :: stream
      brng=VSL_BRNG_MCG31
      seed=7777777
      method=VSL_RNG_METHOD_GAUSSIANMV_BOXMULLER2
      me=VSL_MATRIX_STORAGE_FULL
!     Variance-covariance matrix for test
!     (should be symmetric,positive-definite)
!     This is full storage for dpotrf subroutine
      c(1,1)=16.0D0
      c(1,2)=8.0D0
      c(1,3)=4.0D0
      c(2,1)=8.0D0
      c(2,2)=13.0D0
      c(2,3)=17.0D0
      c(3,1)=4.0D0
      c(3,2)=17.0D0
      c(3,3)=62.0D0
      a(1)=3.0D0
      a(2)=5.0D0
      a(3)=2.0D0
      t  = c
      print *,'Variance-covariance matrix C'
      write (*,'(3F7.3)') c
      print *,''
      print *,'Mean vector a:'
      write (*,'(3F7.3)') a
      print *,''
      print *,'VSL_MATRIX_STORAGE_FULL'
      print *,'-----------------------'
      print *,''
      call dpotrf('U',ndim,t,ndim,info)
!     Stream initialization
      errcode=vslnewstream(stream,brng,seed)
      call CheckVslError(errcode)
!     Generating random numbers
!     from multivariate normal distribution
      errcode=vdrnggaussianmv(method,stream,n,r,ndim,me,a,t)
!     Printing random numbers
      print 11,' Results (first ',nn,' of ',n,')'
      print *,'--------------------------'
11    format(A,I5,A,I5,A)
      do i=1,nn
        print 12,' r(',i,')=(',r(:,i),')'
      end do
12    format(A,I5,A,3F8.3,A)
      print *,''
      call dCalculateGaussianMVSampleCharacteristics(ndim, n, r,        &
     &      dbS, dbS2, dbMean, dbVar, dbCovXY, dbCovXZ, dbCovYZ)
!     Printing
      print *,'Sample characteristics:'
      print *,'      Sample             Theory'
      print 13,' Mean :(',dbMean(1),dbMean(2),dbMean(3),                &
     &         ')  (',a(1),a(2),a(3),')'
      print 13,' Var. :(',dbVar(1),dbVar(2),dbVar(3),                   &
     &         ')  (',c(1,1),c(2,2),c(3,3),')'
      print 14,' CovXY: ',dbCovXY,'          ',c(1,2)
      print 14,' CovXZ: ',dbCovXZ,'          ',c(1,3)
      print 14,' CovYZ: ',dbCovYZ,'          ',c(2,3)
13    format(A,F5.1,F5.1,F5.1,A,F5.1,F5.1,F5.1,A)
14    format(A,F6.1,A,F6.1)
      print *,''
      errcode=dGaussianMVCheckResults(ndim, n, a, c, dbMean, dbVar, S,  &
     &      D2, Q, DeltaM, DeltaD)
      if (errcode /= 0) then
        print *,"Error: sample moments"
        print *,"disagree with theory"
        print 15, "    DeltaM: ", DeltaM(1), DeltaM(2), DeltaM(3)
        print 15, "    DeltaD: ", DeltaD(1), DeltaD(2), DeltaD(3)
        print *,  "   ( at least one of the Deltas > 3.0) "
        stop 1
      else
        print *,"Sample moments"
        print *,"agree with theory"
        print *,  "   ( all Deltas < 3.0) "
      end if
15    format(A,F7.3,F7.3,F7.3)
      print *,''
!     Stream finalization
      errcode=vslDeleteStream(stream)
      end
Andrey_N_Intel
Hi John,
the routine you mention is not part of Intel MKL RNG API but a service routine defined in the errcheck.inc available in the directory with examples. It prints the message in case any of the generator routines used in the example returns error code
Andrey
