HPL-2.3 test on AMD CPU with Intel MPI
skumar1
 We are trying to run an MPI job with pbs pro for HPL benchmarks on AMD processors with intel compilers.   The job got failed. The output log indicates that the job was terminated with the message "BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES."   We request your suggestions to run a job with pbs pro script to test HPL 2.3 using intel MPI on AMD EPYC processor.
Thanks and regards,
Santha Kumar
HPC Administrator
Shiquan_Su
Hi, Santha:
It sounds like an MPI issue. Have you posted your issue on the Intel MPI forum?:
https://community.intel.com/t5/Intel-MPI-Library/bd-p/oneapi-hpc-toolkit
Would you please provide more details about your test? Do you have any output from your test? Can you see any test results for the HPL? In many cases, the BAD TERMINATION happens at the termination stage which means the HPL test has no problem itself.
Shiquan
skumar1
Yes, I posted, waiting for reply
