Help on running GMRES with MKL in C++
Dilshan_Sithira_Priy
I am new to MKL library. I tried to use to use it to solve a sparse system matrix using “GMRES” functions in MKL library.
I tried the steps in the given in examples which come with the MKL library ( “fgmres_st_criterion_c.c”). I was able to compile and run the example with ICC v19.0 ( I am using Windows 10 64bit with Intel Parallel studio 2019. I have a student license). The problem is when I ported the code into my C++ program, nothing seems to be working.
My code is written in C++ and I am using template classes. I am not sure whether this is possible or not. I have included my code until gmres solver is initialized. The initialization fails and the error code is not listed in the documentation (“RCI_request =-3689348814741910324” ). “ipar” variable has wrong values.
Additionally, I notice something strange. Let's say if I am to set “RCI_request =0” (which is not needed) before calling “dfgmres_init”. Then “dfgmres_init” will simply return RCI_request =0. But still, the “ipar” variable values are wrong. I notice the same behavior with the Conjugate Gradient method.
I have 16k elements in my problem but it will be much larger when the mesh is refined. ( n = 16000).
Thank you all in advance
Dilshan
template<class T>
void SPMV<T>::call_gmres_solver_mkl(const vector<T>& coefNeigbor, const vector<T>& RHS,
       vector<T>& phi, vector<T>& phiOld) {
if (sizeof(T) == sizeof(float)) {
              cout << "currently this program is written for double floatting point numbers only.\nplease update the source code and recompiler" << endl;
              cout << "Program will terminate now" << endl;
              cin.get();
              exit(0);
       MKL_INT n = nFl;// number of unknows
       MKL_INT nEle = (nFl + (nFl*nface) - (nTtl - nFl));
       if (nEle <= 0) {
              cout << "The number of interfaces must be greater than zero. current value =" << n << endl;
              cout << "Program will exit now" << endl;
              cin.get();
              exit(0);
MKL_INT RCI_request, itercount, expected_itercount = 8;//
       double *A = (double*)malloc(nEle * sizeof(double));
       double *residual = (double*)malloc(n * sizeof(double));
       int id = 0;
       ia[0] = 0;
       int n0 = n * (2 * n + 1) + (n * (n + 9)) / 2 + 1;
       double *tmp = (double *)malloc(n0 * sizeof(double));
       double *rhs = (double *)malloc(n * sizeof(double));
       double *solution = (double *)malloc(n * sizeof(double));
MKL_INT ipar[128];
       double dpar[128];
// At first run phiOld = 0
for (int i = 0; i < n; i++) {
              solution = phiOld;
              rhs = RHS;
dfgmres_init(&n, solution, rhs, &RCI_request, ipar, dpar, tmp);
if (RCI_request != 0) {
cout << "Some error occured during the gmres initialisation phase. Error code =" << RCI_request << endl;
       goto FAILED;
// rest of the code
mecej4
Please provide the answer to Gennady's question. I suspect that you have changed MKL_INT without choosing the corresponding proper settings to use ILP64 libraries instead of LP64 libraries. You may find it useful to print (with printf() or cout) the value of sizeof(RCI_request) just before the call to dfgmres_init().
mecej4
Decimal ‭-3689348814741910324 is 0xCCCCCCCCCCCCCCCC‬, so I suspect that your code is not calling the MKL routine(s) with the correct ABI. You seem to be passing integer arguments to MKL as 64-bit integers; was that your intention?
MKL is intended to be called from Fortran, C, and anything else that makes C-like calls. It is up to you to make sure that your C++ code calls MKL in a compatible manner.
If you want more help with this problem, please post the full source code, rather than snippets.
Gennady_F_Intel
and show how do you link this example
Thank you for the reply.
As I mentioned, I am new to using MKL. there was no special requirement for using 64bit integer data types, I have simply followed the provided example files and the user manual ( Intel Math Kernel Library reference guide.pdf - 2019, page 1812).
previously included code is a small section of large flow code and I have included the function containing gmres call, attaching the entire code is not possible therefore I have attached a relevant section of the source code ("gmres.h") and also the example ( "fgmres_st_criterion_c.c"  ) since it was mentioned.
It will be a great help if someone can provide some documentation or example how to use these sparse solvers in C++ environment.
thank you
Dilshan
mecej4
thank you mecej4, for the tip. you are right, I was not using the correct ILP64 setting. Any guess why it was possible for me to run "fgmres_st_criterion_c.c" file without using the correct setting? by the way, previously I did not understand what Gennady asked. sorry for that.
thank you very much for your time.
Dilshan
houjy
I have the same problem with you, and I would like to ask how to use ILP64 correctly.
my way using ILP64 is:
#define MKL_ILP64
and my problem is call dfgmres_init(), RCI_request=‭-3689348814741910324.
Thank you very much
