7302 Discussions
Help w/ Visual Studio 2022 and Fortran Compiler
MartinStephenson
I am looking for Vipin_s_Intel,
When I open Visual Studio, I receive the following message:
Do you have suggestions on how I can resolve this?
We followed the troubleshooting steps below and now obtain the above window when I start up MS Visual Studio 2022.  Can you point me to the proper group at Microsoft if this outside of Intel's troubleshooting capabilities?  Lastly, I can compile a program.  However, I cannot figure out how to run it.  Below is the window in MS Visual Studio 2022.
I am sure that i am missing something basic.  Thank you, Vipin. - Martin
MartinStephenson
Hi Aleksandra,
I used the Parallel option.  Everything is working well.  See the screenshot below.
Thank you for all of your help, Aleksandra.
Martin
Vipin_S_Intel
Hi Martin,
Thank you for getting back to me! I completely understand how important it is to get this sorted.
In order to investigate the correct version of Visual Studio and its build, I just need to confirm a few details. To check if the compiler is properly integrated, could you please follow these steps and share a screenshot?
  1. Inside Visual Studio, go to Help > About Microsoft Visual Studio.
  2. Take a screenshot showing the components of the toolkit.
Once I have the screenshot, I’ll do my best to reproduce the issue and help you resolve it.
Note: Following our security policy, I have edited your original post, as it included a few download links. If any of the details you need to share contain confidential information, such as product details or serial numbers, please reply or post them via private message.
Looking forward to your response!
Have a great day ahead!
MartinStephenson
Hi Vipin,
I took three screen shots so that you can see the entire menu.
Below is a copy of each shot and attached are png files of each screenshot.
Here is a screenshot of the installation.
We downloaded both the C++ and the Fortran Compiler.
I was able to figure out how to run a program.  I simply hit
the Cyrl+F5 Button or the 'Debug menu and selected 'Start without Debugging.'
A second question topic, is that I saw several libraries included when I/ we
downloaded the programs.  One was a Math Kernal Library.  In the past,
I used the IMSL Subroutines to solve a set of equations via say Gaussian
Elimination of a full or a banded matrix.  I included a statement in my code
stating 'USE IMSL' and then I simply called the Subroutine that I needed.
Do any of the libraries in the list above have Subroutines that I can simply
call from any of the libraries?
Thank you, Vipin.
Martin Stephenson
MartinStephenson
Hi Vipin,
Thank you for escalating my case.  Hopefully, someone can resolve this soon.
downloaded the programs.  One was a Math Kernal Library.  See attached
screenshot.
In the past, I used the IMSL Subroutines to solve a set of equations via say
Gaussian Elimination of a full or a banded matrix.  I included a statement
in my code stating 'USE IMSL' and then I simply called the Subroutine that
I needed.  Do any of the libraries in the list above have Subroutines that I
can simply call from any of the libraries?
Thank you again, Vipin.
Martin Stephenson
Vipin_S_Intel
Hi Martin,
I have sent you a private message. Please check your community inbox.
MartinStephenson
Hi Vipin,
Below is a Screen Shot of the 'About Microsoft Visual Studio' window that opened.
I cannot enlarge this window by hovering my mouse over the edge or corner of this window until the cursor changes to a resizing icon, then click and drag to resize.   The Cursor does not change.  I was able to click on the 'Copy Info' icon to capture all of the information in this window.  This information is in the attached MS Word document that contains the information of the installed products.  Please open this attached MS Word document.  It will have all of the information that you are seeking.  I hope that you can now reproduce the issue and help me resolve it.
Thank you, Vipin.
andrew_4619
In relation to the original post I also get that pop up and also periodically another similar one. They are irritationing but OI have be ignoring for several months with no ill effects.
You seem to have made a debug build which can be run in VS under the debug menu options.
JohnNichols
Honored Contributor I
This occurs from time to time, like Andrew one ignores stuff that does not stop the build.
Aleksandra_K
For the list of linear equation computational routines in oneMKL please refer to LAPACK Linear Equation Computational Routines
Aleksandra
MartinStephenson
Thank you for your response, Aleksandra.
I went to the link that you sent me and saw the DGESV Example Program in Fortran link.
https://www.intel.com/content/www/us/en/docs/onemkl/code-samples-lapack/2022-1/dgesv-example.html#:~:text=%3Fgesv%20function-,DGESV%20Example%20Program%20in%20Fortran,-DGESV%20Example%20Program
I saw the following lines on how to use the DGESV routine.
*     Solve the equations A*X = B.
      CALL DGESV( N, NRHS, A, LDA, IPIV, B, LDB, INFO )
In what variable does DGESV return the solution 'X?'
The input variables are defined in the example as:
*     .. Parameters ..
      INTEGER          N, NRHS
      PARAMETER        ( N = 5, NRHS = 3 )
      INTEGER          LDA, LDB
      PARAMETER        ( LDA = N, LDB = N )
*     .. Local Scalars ..
      INTEGER          INFO
*     .. Local Arrays ..
      INTEGER          IPIV( N )
      DOUBLE PRECISION A( LDA, N ), B( LDB, NRHS )
'A' is the matrix
'B' is the Right-Hand Side
I do not see the array 'X' being declared.
Also, to call the routine DGSEV, do I simply write:  'EXTERNAL         DGESV'
and then call this routine like in the example?
Thank you, Alexsandra
Aleksandra_K
The parameter b is overwritten by the solution matrix X, where the columns are the corresponding solutions. Here are all the details of this routine ?gesv.
Alex
MartinStephenson
Your response was very helpful, Alex.  I will be on the right track.
To use a library of subroutines one needs to write:
Use MIMSL
To use the Math Kernal Library subroutines, do I only need to only
call the routine like:
 or do I also need to put in a statement like 'USE Math Kernal Library'
in addition to the Call statement above?
Thank you, Alex.
Martin
Aleksandra_K
You don't need to write 'USE Math Kernel Library'. In general, you need to set the environment variables (Setting Environment Variables) and link your project with oneMKL (Automatically Linking Your Intel® Fortran Project with oneMKL).
I also recommend looking at the developer's Getting Started guide for more useful information and examples.
Alex
Aleksandra_K
Did you have a chance to try my suggestions?
Alex
MartinStephenson
Yes.  I am trying them now.
On one of the urls, I see the following:
Configure your Intel® Fortran project for automatic linking with Intel® oneAPI Math Kernel Library (oneMKL) as follows:
  1. Go to Project > Properties > Fortran > Libraries > Use Intel Math Kernel Library and select Parallel, Sequential, or Cluster as appropriate.
  2. If your project requires the ILP64 interfaces, change the Use ILP64 interfaces property setting by selecting Yes.
Which one should I pick, Parallel, Sequential, or Cluster?
MartinStephenson
Hi Aleksandra,
Martin
