Help with convolving data sets
xraygenfit
Hi guys,
I've been banging my head against the wall trying to convolve two data sets. They are of equal length. One is a gaussian, and the other is a Lorentzian. I haven't been able to get it to work using a regular convolution.
i.e.
for (j = 0; j < 64; j += 1)
y= 0.0;
for (i = 0; i <= j; i++)
y += x * h[j - i];
and I haven't been able to get it to work using a Fourier Transform (see below). My convolution is orders of magnitude larger than the input functions and a completely wrong shape.
Now, I have been getting all of my information about this from Google, so I must be missing something pretty obvious. Especially since both ways of doing it are failing for me. I know this isn't completely related to the MKL, but I plan on using the MKL wrappers for fftw after i get my test case working. If anyone could give me a hand with either the FT or regular convolution, I would really appreciate it. You can download the project from here
Convolution project
I know I'm using the FFTW correctly, as I can FT and inverse FT a function without a problem. Thanks for any help.
#include "stdafx.h"
#include
#include
#include
#include "fftw3.h"
using namespace std;
int _tmain(int argc, _TCHAR* argv[])
double *x = (double*)fftw_malloc(1000*sizeof(double));
double *y = (double*)fftw_malloc(1000*sizeof(double));
double *conv3 = (double*)fftw_malloc(1000*sizeof(double));
int NumberofPoints = 0;
fftw_plan p;
fftw_complex* out1 = (fftw_complex*) fftw_malloc(sizeof(fftw_complex) * 1000);
fftw_complex* out2 = (fftw_complex*) fftw_malloc(sizeof(fftw_complex) * 1000);
fftw_complex* final = (fftw_complex*) fftw_malloc(sizeof(fftw_complex)* 1000);
for(int i = 0; i < NumberofPoints; i++)
out1[0] = 0;
out1[1] = 0;
out2[0] = 0;
out2[1] = 0;
final[0] = 0;
final[1] = 0;
//Read in our files
ifstream stream("individgraphs.dat");
if(stream.is_open() == false)
cout << "Error" << endl;
while(stream >> x[NumberofPoints]>>y[NumberofPoints])
NumberofPoints++;
stream.close();
//FFTW
//FT data file 1
p = fftw_plan_dft_r2c_1d(NumberofPoint s, x, out1, FFTW_ESTIMATE);
fftw_execute(p);
fftw_destroy_plan(p);
//FT data file 2
p = fftw_plan_dft_r2c_1d(NumberofPoints, y, out2, FFTW_ESTIMATE);
fftw_execute(p);
//Convolution - Complex multiplication and scaling
final[0] = (out1[0]*out2[0]-out1[1]*out2[1])*(1.0/(double)NumberofPoints);
final[1] = (out1[0]*out2[1]+out1[1]*out2[0])*(1.0/(double)NumberofPoints);
//Invert the product
p = fftw_plan_dft_c2r_1d(NumberofPoints, final, conv3,FFTW_ESTIMATE);
fftw_execute(p);
//Write output file
ofstream test("outfile.txt");
for (int i = 0; i < NumberofPoints; i++)
test << conv3/NumberofPoints << endl;
test.close();
//Free memory
fftw_free(x);
fftw_free(y);
fftw_free(out1);
fftw_free(out2);
fftw_free(conv3);
getch();
return 0;
