7303 Discussions
Help with sparse matrix multiplication in MKL
Disha
I'm trying to multiply sparse x dense matrix using MKL. The output matrix appears to be wrong. Is there any issue with initializing matrix A? I'm running the code on DevCloud. Could someone help me with this?
#include <stdio.h>
#include <stdlib.h>
#include "mkl.h"
#include "mkl_spblas.h"
#include <stdbool.h>
#define CALL_AND_CHECK_STATUS(function, error_message) do { \
          if(function != SPARSE_STATUS_SUCCESS)             \
          printf(error_message); fflush(0);                 \
          status = 1;                                       \
} while(0)
/* Consider adjusting LOOP_COUNT based on the performance of your computer */
/* to make sure that total run time is at least 1 second */
#define LOOP_COUNT 10
int main()
    double *B, *C, *values, *rv;
    int m, n, p, i, r, j, count, number;
    double alpha, beta;
    double s_initial, s_elapsed;
    sparse_matrix_t A = NULL;
    sparse_operation_t operation = SPARSE_OPERATION_NON_TRANSPOSE;
    struct matrix_descr descrA;
    descrA.type = SPARSE_MATRIX_TYPE_GENERAL;
    sparse_layout_t layout = SPARSE_LAYOUT_ROW_MAJOR;
    sparse_index_base_t indexing = SPARSE_INDEX_BASE_ZERO;
    MKL_INT *rows;
    MKL_INT status;
    MKL_INT *col_indx;
    MKL_INT *bi, *ei, *indx;
    m = p = n = 4;
    printf (" Initializing data for matrix multiplication C=A*B for matrix \n"
            " A(%ix%i) and matrix B(%ix%i)\n\n", m, p, p, n);
    alpha = 1.0; beta = 0.0;
    printf (" Allocating memory for matrices aligned on 64-byte boundary for better \n"
            " performance \n\n");
    values = (double *)mkl_malloc( m *sizeof( double ), 64 );
    B = (double *)mkl_malloc( p*n *sizeof( double ), 64 );
    C = (double *)mkl_malloc( m*n *sizeof( double ), 64 );
    col_indx = (MKL_INT *)mkl_malloc(m *sizeof(MKL_INT), 64);
    rows = (MKL_INT *)mkl_malloc((m + 1) *sizeof(MKL_INT), 64);
    printf (" Intializing matrix data \n\n");
    for( i = 0; i < m; i++ )
          values[i] = (rand() % (20 - 1 + 1)) + 1;
    for( i = 0; i < m; i++)
          col_indx[i] = i % 3;
    rows[0] = 0;
    for( i = 1; i < (m + 1); i++ )
          rows[i] = rows[i - 1] + 2;
    for (i = 0; i < (p*n); i++)
        B[i] = (double)(i+1);
    for (i = 0; i < (m*n); i++)
        C[i] = 0.0;
    printf (" Making the first run of matrix product using Intel(R) MKL to get stable run time measurements \n\n");
    mkl_sparse_d_create_csr (&A, indexing, m, p, rows, rows + 1, col_indx, values);
    mkl_sparse_d_export_csr (A, &indexing, rows, col_indx, &bi, &ei, &indx, &rv);
    printf("\nMatrix A \n");
    for(i = 0; i < p; i++)
        for(long l = 0; l < p; l++)
                bool flag = false;
                for(long j = bi[i]; j < ei[i]; j++)
                        if(indx[j] == l)
                                flag = true;
                                printf("%.0lf ", rv[j]);
                                break;
                if(!flag)
                        printf("%d ",0);
        }       printf("\n");
    printf("\n Matrix B \n");
    for (i = 0; i < p; i++)
        printf("\n");
        for (j = 0; j < n; j++)
        printf(" %f ",*( B + i * n + j));
    CALL_AND_CHECK_STATUS (mkl_sparse_d_mm(operation, alpha, A, descrA, layout, B, n, p, beta, C, m), "Error after MKL_SPARSE_D_MV, csrC*x  \n");
    printf (" Measuring performance of matrix product using Intel(R) MKL \n\n");
    s_initial = dsecnd();
    for (r = 0; r < LOOP_COUNT; r++)
    s_elapsed = (dsecnd() - s_initial) / LOOP_COUNT;
    printf (" == Matrix multiplication using Intel(R) MKL completed == \n"
            " == at %.5f milliseconds == \n\n", (s_elapsed * 1000));
    for (i = 0; i < m; i++)
            printf("\n");
            printf(" %f ", *(C + i * n + j));
    printf ("\n Deallocating memory \n\n");
    mkl_free(A);
    mkl_free(B);
    mkl_free(C);
    if (s_elapsed < 0.9/LOOP_COUNT) {
        s_elapsed=1.0/LOOP_COUNT/s_elapsed;
        i=(int)(s_elapsed*LOOP_COUNT)+1;
        printf(" It is highly recommended to define LOOP_COUNT for this example on your \n"
               " computer as %i to have total execution time about 1 second for reliability \n"
               " of measurements\n\n", i);
    printf (" Example completed. \n\n");
    return 0;
Gennady_F_Intel
How could we check the case? You may try to initialize the input data manually then compute and compare the output results.
