Help with this Paradiso Example Please
marcias_martinez
Hi Guys,
I am new with the IMKL 8.0 library using MS Visual C++ Version 7.1
I am able tu run the Paradiso Example Sparse Direct.cpp
Then I proceeded to modify the program to read in a matrix and perform a similar calculation. The matrix is a 10 by 10 that looks like this:
12368463120
2100000000
3010000000
6001000000
8000100000
4000010000
6000001000
3000000100
1000000010
20000000001
The B vector looks like this:
1
2
0
0
3
6
5
1
1
6
I am trying to learn how to use this but (under the example program everything works) when I modified to read this matrix in I get an error when performing
error = dss_factor_real( handle, type, values );
The message that I get is: The program '[788] Paradiso Example Sparse Direct.exe: Native' has exited with code -1 (0xffffffff)
Any ideas, the code is set here below:
Thanks in advance..
Marcias Martinez
// Paradiso Example Sparse Direct.cpp : Defines the entry point for the console application.
* Copyright(C) 2001-2004 Intel Corporation. All Rights Reserved.
* The source code contained or described herein and all documents related to
* the source code ("Material") are owned by Intel Corporation or its suppliers
* or licensors. Title to the Material remains with Intel Corporation or its
* suppliers and licensors. The Material contains trade secrets and proprietary
* and confidential information of Intel or its suppliers and licensors. The
* Material is protected by worldwide copyright and trade secret laws and
* treaty provisions. No part of the Material may be used, copied, reproduced,
* modified, published, uploaded, posted, transmitted, distributed or disclosed
* in any way without Intel's prior express written permission.
* No license under any patent, copyright, trade secret or other intellectual
* property right is granted to or conferred upon you by disclosure or delivery
* of the Materials, either expressly, by implication, inducement, estoppel or
* otherwise. Any license under such intellectual property rights must be
* express and approved by Intel in writing.
* Content : Intel MKL DSS C example
#include "stdafx.h"
#define< FONT color=#000000> NROWS 5
#define NROWSV 10
#define NCOLS 5
#define NCOLS_V 10
#define NNONZEROS 9
#define NNONZEROS_V 19
#define NRHS 1
#define TESTINT 1
static const int nRows = NROWS ;
static const int nRows_V = NROWSV ;
static const int nCols = NCOLS ;
static const int nCols_V = NCOLS_V ;
static const int nNonZeros = NNONZEROS ;
static const int nNonZeros_V = NNONZEROS_V ;
static const int nRhs = NRHS ;
static _INTEGER_t rowIndex[NROWS+1]; //= { 1, 6, 7, 8, 9, 10 };
static _INTEGER_t rowIndex_V[11]; //= { 1, 6, 7, 8, 9, 10 };
static const int perm[11];
static _INTEGER_t columns[NNONZEROS];// = { 1, 2, 3, 4, 5, 2, 3, 4, 5 };
static _INTEGER_t co lumns_V[nNonZeros_V];
static _DOUBLE_PRECISION_t values[NNONZEROS]; // = { 9, 1.5, 6, .75, 3, 0.5, 12, .625, 16 };
static _DOUBLE_PRECISION_t values_v[nNonZeros_V];
static _DOUBLE_PRECISION_t rhs[NCOLS]; //= { 1, 2, 3, 4, 5 };
static _DOUBLE_PRECISION_t rhs_V[NCOLS_V];
double GSM[10][10];
//static _DOUBLE_PRECISION_t test[TESTINT];
void main() {
int i, j, k,l;
/* Allocate storage for the solver handle and the right-hand side. */
_DOUBLE_PRECISION_t solValues[NROWSV];
_MKL_DSS_HANDLE_t handle;
_INTEGER_t error;
_CHARACTER_STR_t statIn[] = "determinant";
_DOUBLE_PRECISION_t statOut[5];
//int opt =MKL_DSS_MY_ORDER;
int opt = MKL_DSS_DEFAULTS;
int sym = MKL_DSS_SYMMETRIC;
int type = MKL_DSS_POSITIVE_DEFINITE;
int stop;
/* Read data in from File */
// The next step is to be able to store this in dynamic arrays that I can insert
// into the solver.
// Input of the K-Matrix Square and the B Vector
std::ifstream inB;
inB.open("b_vector2.txt"); //open file for input
if (!inB){
std::cout<< " Connot open file ";
// handle error
std::cin >> stop;
exit(0);
} // End if
for(i=0; i
inB >> rhs_V;
} // End for Topology i
inB.close();
std::ifstream inK;
inK.open("K-Matrix_Square2.txt"); //open file for input
if (!inK){
// handle error
std::cin >> stop;
exit(0);
} // End if
for(i=0; i
for(j=0; j
inK >> GSM;
} // end for j
inK.close();
// Here we loop through the GSM matrix to determine how many non zeroswe have.
k=0;
// To determine the size of the array.
for(i=0; i<10; i++){
for(j=i; j<10; j++){
//rhs_V=0;
if(GSM != 0.0){
k++;
} // end if
} // end for j
k=0;
l=1;
int p, nonzerovalues_in_row;
p =-1;
nonzerovalues_in_row =0;
rowIndex_V[0]=1;
if(GSM != 0.0){
values_v=GSM;
columns_V=j+1;
k++;
nonzerovalues_in_row++;
} // end for j
} // End for Topology j
p++;
rowIndex_V[p+1]= rowIndex_V
+nonzerovalues_in_row;
std::ifstream indata;
indata.open("calc.txt"); //open file for input
if (!indata){
// handle error
std::cin >> stop;
exit(0);
} // End if
for(i=0; i
indata >> values;
for(i=0; i
indata >> rhs;
for(i=0; i
indata >> columns;
for(i=0; i<=NROWS; i++){
indata >> rowIndex;
/* Initialize the solver */
error = dss_create(handle, opt);
if ( error != MKL_DSS_SUCCESS ) goto printError;
/* Define the non-zero structure of the matrix */
error = dss_define_structure(
handle, sym, rowIndex_V, nRows_V, nCols_V,
< P>columns_V, nNonZeros_V );
/* Reorder the matrix */
error = dss_reorder( handle, opt, 0);
/* Factor the matrix */
error = dss_factor_real( handle, type, values_v);
/* Get the solution vector */
error = dss_solve_real( handle, opt, rhs_V, nRhs, solValues );
/* Get the determinant */
error = dss_statistics(handle, opt, statIn, statOut);
/* print determinant */
printf(" determinant power is %g ", statOut[0]);
printf(" determinant base is %g ", statOut[1]);
printf(" Determinant is %g ", (pow(10.0,statOut[0]))*statOut[1]);
//free((void *) statIn);
/* Deallocate solver storage */
error = dss_delete( handle, opt );
/* Print solution vector */
printf(" Solution array: ");
for(i = 0; i< nCols; i++)
printf(" %g", solValues );
printf(" ");
exit(0);
printError:
printf("Solver returned error code %d ", error);
exit(1);
