7302 Discussions
How to copy from a global matrix to distributed matrix in Scalapack?
jsjie
I would like to use pzhengst and others to solve an eigenvalue problem Ax=λBx. Thus, I need to copy from global A and B matrix to distributed ones. However, when calculating A and B, mpi_allreduce is used, so every process has the whole global A and B matrix.
I suppose in this case, zgebs2d and zgebr2d are inefficient, because there is no need for broadcasting? If this is the case, how should I copy from global A matrix to the distributed ones? Should I just pretend that A is a distributed matrix, like suggested in this thread , maybe by generating a context with nprow = npcol = 1, and then generating a desc with nb = n = lld?
Besides, what is the difference between p?lacp2 and p?lacpy? I've checked their documentatino, and found no difference except for the direction of copy.
Fengrui
Thank you for posting in the forum!
One thing you could try is to use infog2l function like in the in-package examples (in the file matrix_generator.h). It is to loop over the global matrix and only copy the data to local when iarow==myrow and iacol==mycol. No communication is needed as all processes possess the whole A and B.
For the difference between p?lacp2 and p?lacpy, the former requires that only one dimension of the matrix is distributed, that is the local columns of A are in the same process column or the local rows of A are in the same process row.
Best,
Fengrui
Fengrui
Best,
Fengrui
