How to get Cholesky diagonal?
vladimir1
Hello
I need to extract diagonal from cholesky LDLt sparse factorization. Can I do this with Intel MKL?
I can use pardiso to factor and solve sparse linear system. But cholesky factor matrix itself is unreachable for me.
Kirill_V_Intel
Hello Vladimir,
Are you looking for something like pardiso_getdiag? https://software.intel.com/en-us/mkl-developer-reference-c-pardiso-getdiag
Or do you need factor L?
Best,
Kirill
vladimir1
Thank you so much. I somehow did not see it
vladimir1
One more question.
Documentation for pardiso_getdiag says that "it is possible that array df is not in line with the perm array computed during phase 11".
How can I get correct permutations of diagonal elements of the factorized matrix after factorization?
Kirill_V_Intel
Hello again,
The reason for the note is the internal pivoting which is essential for the stability of the algorithm, especially for non-symmetric matrices. I believe if you turn the pivoting off (iparm[20] = 0, https://software.intel.com/en-us/mkl-developer-reference-c-pardiso-iparm-parameter) you should get the correct diagonal values (which agree with the perm returned after phase 11).
If this is not an option for you, we could add it as a feature request in our to-do list. Or, if you tell us what goal you want to achieve by using the diagonal, we might possibly suggest an alternative option.
Best,
Kirill
