How to install cluster pardiso
Vol-ST
I've installed pardiso using offline installer. I got the following error when I tried to link the lmkl_blacs_mpi_ilp64 for custer pardiso.
/usr/bin/ld: cannot find -lmkl_blacs_mpi_ilp64: No such file or directory
RahulC_Intel
Hi Sheng, we are routing your concern to the respective team and they will get back to you as soon as possible.
VarshaS_Intel
Could you please let us know the OS, Hardware, and Intel MKL version you are using?
Could you please provide us with the complete steps you followed to reproduce the error on our end?
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. Could you please provide us with an update?
Thanks & Regards,
Varsha
Vol-ST
Hi Varsha,
Here is my OS and hardware information, and I am using  sudo apt install intel-oneapi-mkl to install.
1. OS
Description: Ubuntu 22.04.3 LTS
Release: 22.04
2. CPU
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 48 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 24
On-line CPU(s) list: 0-23
Vendor ID: AuthenticAMD
Model name: AMD Ryzen 9 5900X 12-Core Processor
3. OpenAPI version: 2024.0.0-49656
VarshaS_Intel
Thanks for your reply and details.
Could you please confirm whether you are getting the error while installing or running any sample MKL code so that we could reproduce the issue and check further?
On our end, we tried using the same command and we were able to install it without any error. We are also able to run the sample codes. Please find the below for more details:
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. Could you please provide us with an update on your issue?
Thanks & Regards,
Varsha
Vol-ST
Hi Varsha,
Looks like it works without linking  lmkl_blacs_mpi_ilp64.
Thanks & Regards,
Sheng
VarshaS_Intel
Thanks for your reply.
It's great to know that your issue is resolved. It’s great to know that the issue has been resolved, in case you run into any other issues please feel free to create a new thread.
Thanks & Regards,
Varsha
