How to use MKL with G++
jbgao
Hi All
WHat is the correct command for using MKL with g++ compiler in Redhat Linux EL 64 bit?
Thanks a lot
jbgao
TimP
The use of MKL with g++ need not be any different than with other supported compilers. If you use g++ -fopenmp along with threaded MKL, you must use the libiomp5 of MKL 10, not libguide or libgomp.
minifat
There's a example directory, you may refer to the Makefile or output of the compiling and linking process.
