How to use mkl on M2 mac
Shun3
I want to use mkl on m2 mac.
I get the following warning when I try to compile.
"ld: warning: ignoring file /opt/intel/oneapi/compiler/latest/mac/compiler/lib/libiomp5.dylib, building for macOS-arm64 but attempting to link with file built for macOS-x86_64"
Is it not available for m2 mac?
If you run the following HP cmake, the makefile will be created without any problems.
https://www.intel.com/content/www/us/en/docs/onemkl/developer-guide-macos/2023-0/cmake-config-for-onemkl.html
iberico@ibericonoMac-mini build % ls
CMakeCache.txt  CMakeFiles/
iberico@ibericonoMac-mini build % cmake ..
-- MKL_ARCH: intel64
-- MKL_LINK: dynamic
-- MKL_INTERFACE_FULL: intel_ilp64
-- MKL_THREADING: intel_thread
-- MKL_MPI: mpich
-- Found MKL: mpich
-- Found MKL: /opt/intel/oneapi/mkl/2023.1.0
-- Found MKL: /opt/intel/oneapi/mkl/2023.1.0/lib/libmkl_intel_ilp64.dylib
-- Found MKL: /opt/intel/oneapi/mkl/2023.1.0/lib/libmkl_intel_thread.dylib
-- Found MKL: /opt/intel/oneapi/mkl/2023.1.0/lib/libmkl_core.dylib
-- Found MKL: /opt/intel/oneapi/compiler/latest/mac/compiler/lib/libiomp5.dylib
-- Configuring done (0.0s)
-- Generating done (0.0s)
-- Build files have been written to: /Users/iberico/my_program/03_test_program/mkl_test/test/build
If you know of a solution, please let me know.
PraneethA_Intel
Hi Ogawa,
Thanks for posting in Intel communities.
Please see the below URL for a list of the OS/compilers/architectures supported by Intel MKL.
https://www.intel.com/content/www/us/en/developer/articles/system-requirements/oneapi-math-kernel-library-system-requirements.html
Thanks and Regards,
Praneeth Achanta
PraneethA_Intel
Hi Ogawa,
We have not heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Praneeth Achanta
PraneethA_Intel
Hi Ogawa,
We have not heard back from you. We hope the information provided helped. If you need any additional information please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
Praneeth Achanta
BirkS
This is still an issue with the latest version of oneAPI. It appear in the bottom row here, that MKL on macOS only is available in an x64 version but not an arm64 version.:
https://www.intel.com/content/www/us/en/docs/oneapi/installation-guide-macos/2023-0/pip.html
This is rapidly becoming an issue for a lot of developers using Apple devices. Will there be support for this growing architecture, and in that case - when can it be expected?
Kind regards,
Birk
