7301 Discussions
I am not able to get any node for computation from ubuntu terminal
SSabu
From 2-3 days, I am not getting any node for computation , even after waiting for 1-2 hours. And, I am able to access terminal on jupyter notebook. Can you please assist me in knowing why I am unable to get node from ubuntu terminal?
Aswathy_C_Intel
Are you trying 'qsub -I' to get the compute node. If so, please try it once again and confirm. If the issue still persist, please share the command used and the screenshot of the issue.
SSabu
I tried both variations- "qsub -I" and "qsub -i -l walltime=24:00:00"
it just doesn't respond for 1-2 hours. And after 2 hours, I get the broken pipe message.
Thanking you
Aswathy_C_Intel
Please try with 'qsub -I' only.
Could you please share the screenshot with 'qsub -I'.
If you want to run a job for 24hrs, you can set the wall time inside the job file you want to submit.
Please find a sample python file(test.py) submission.
1.vi job
2.Add the following in job file and save.
#PBS -l walltime=24:00:00
cd $PBS_O_WORKDIR
source activate YOUR_ENV
python test.py
3.Run as 'qsub job'
4.To see the status, use 'qstat'.
SSabu
I already told you, I have tried both cases and I am having the same problem. Same error is coming.
Please look for solving the problem.
Aswathy_C_Intel
We could not recreate your issue from our side. PFB the screenshot.case0466642.JPG
Let's continue the discussion over email.
Aswathy_C_Intel
As per the discussion over email, we are closing this thread. Please raise another thread for new issues.
After case closure, you will receive a survey email. We appreciate it if you can complete this survey regarding the support you received.
