7303 Discussions
I get an error in MKL function vsldCorrExec, why?
caden_g_
I want to get
array h[16]={16,15,14,13,
            12,11,10,9,
            8,7,6,5,
            4,3,2,1,},
but I get an error:
line 41:"status = vsldCorrExec(task, f, f_stride, g, g_stride, h, h_stride);" status is not VSL_STATUS_OK,it is VSL_CC_ERROR_DECIMATION,so how to set the decimation with vslCorrSetDecimation?
If I delete "status = vslCorrSetStart(task, h_start);" in code, it will work normally, and
array h[16]={0,0,0,0,
            0,16,15,14,
            0,12,11,10,
            0,8,7,6}.
What can I do?
#include <assert.h>
#include <mkl.h>
#include <iostream>
using namespace std;
int main()
   //input
   const double f[16] = { 1 , 2 , 3 , 4,
                          5 , 6 , 7 , 8,
                          9 , 10, 11, 12,
                          13, 14, 15, 16,};
   //kernel, a simple example
   const double g[9] = { 0, 0, 0,
                         0, 1, 0,
                         0, 0, 0 };
   //output
   double h[16] = { 0 };
   VSLCorrTaskPtr task;
   MKL_INT f_shape[2] = { 4, 4 };
   MKL_INT g_shape[2] = { 3, 3 };
   MKL_INT h_shape[2] = { 4, 4 };
   MKL_INT h_start[2] = { 1, 1 };
   MKL_INT f_stride[2] = { f_shape[1], 1 };
   MKL_INT g_stride[2] = { g_shape[1], 1 };
   MKL_INT h_stride[2] = { h_shape[1], 1 };
   int status;
   status = vsldCorrNewTask(&task, VSL_CORR_MODE_DIRECT, 2, f_shape, g_shape, h_shape);
   assert(status == VSL_STATUS_OK);
   //always get wrong,return -2303(VSL_CC_ERROR_DECIMATION) I can't find and solve the problem
   status = vslCorrDeleteTask(&task);
   //print the result
   for (int r = 0; r < 4; r++)
      cout << r << "(output): ";
      for (int c = 0; c < 4; c++)
         cout << h[r * 4 + c] << " ";
      cout << endl;
   return 0;
Zhen_Z_Intel
Hi caden,
It must belong to the interval Rnmin≤ start(n) ≤ Rnmax. And while you setStart, the Rnmin will be replaced by start(n). And the output(n) should be equals to start(n) + (kn-1) that 1 ≤ kn≤ xshape(n).
In your program, xshape[0]&xshape[1]=4,
=> the Rnmin=-3
If you set size of zshape=4*4, that means you could move from left-top side to right-bottom side by 2 steps, thus, Rnmax=-3+2=-1
int h_start[2]={-3,-3};
And the output should be same as without using SetStart function. If you set zshape to 3*3, that means, -3≤ start(n) ≤0, that Rnmax=0.
Fiona
caden_g_
Fiona Z. (Intel) wrote:
Hi caden,
=> the Rnmin=-3
Fiona
thank you,Fiona.
According to your suggestion,I solve this problem.But if I write "int h_start[2]={-3,-3};",the result is wrong,too.
the array h[16] is {0,0,0,0,
            0,16,15,14,
            0,12,11,10,
            0,8,7,6}.
Instead of
int h_start[2]={-2,-2};
then it will be right, the array h[16] is
{16,15,14,13,
12,11,10,9,
8,7,6,5,
4,3,2,1,},
Zhen_Z_Intel
Hi caden,
I just thought you want to print left-top corner of result matrix. The scale of start(n) is between  -3~-1 in this program, if you set start(n) out of range. There will be an error. Anyway, you could fix program and get result what you want.
Fiona
