7303 Discussions
I have a problem with MKL, results are wrong, why?
Alper_Basturk
Hi everybody,
I am new on MKL. I try to make matrix product, but results are wrong, i can not solve the problem. Would you kindly help me, I will be pleased.
Thanks in advance.
Source Code #1:
//transa and transb are "n"
#include
#include
#include
void main()
char* trans="n";
double alpha=1.0;
double beta=0.0;
int lda=2;
int ldb=4;
int ldc=2;
int m=2;
int n=3;
int k=4;
int i,j;
double a[2][4];
double b[4][3];
double c[2][3];
printf("a matrisi\\n");
for(i=0;i
for(j=0;j
a=i*j+1.2;
printf("%.02f\\t",a);
printf("\\n\\n");
printf("b mmatrisi\\n");
for(i=0;i
for(j=0;j
b=i*j+0.5;
printf("%.02f\\t",b);
printf("\\n\\n");
dgemm(trans,trans,&m,&n,&k,α,(double*)a,&lda,(double*)b,&ldb,β,(double*)c,&ldc);
printf("a*b matrisi\\n");
for(i=0;i
for(j=0;j
printf("%f\\t",c);
printf("\\n");
getch();
Source Code #2:
//transa and transb are "t"
#include
#include
#include
void main()
char* trans="t";
double alpha=1.0;
double beta=0.0;
int lda=4;
int ldb=3;
int ldc=2;
int m=2;
int n=3;
int k=4;
int i,j;
double a[2][4];
double b[4][3];
double c[2][3];
for(i=0;i
for(j=0;j
a=i*j+1.2;
printf("\\n\\n");
for(i=0;i
for(j=0;j
b=i*j+0.5;
printf("\\n\\n");
for(i=0;i
for(j=0;j
printf("%f\\t",c);
printf("\\n");
getch();
and respected result is below
2.4 9.6 16.8
5.4 26.6 47.8
but i can notcalculate this result. Please run my source codes and then give your results, i think there is something wrong with my codes, but i can not find.
Thanks again.
Gennady_F_Intel
alper,
the causeof the problem you're experiencing is that this function ( dgemm ) uses ( expects) fortran notation but you are using C-notation.
Please usecblas_dgemm(....)instead of dgemm.
Rewrite your test, for example, like this:
double a[2][4];
double b[4][3];
double c[2][3];
int lda=4;
int ldb=3;
int ldc=3;
cblas_dgemm(CblasRowMajor, CblasNoTrans, CblasNoTrans, m, n, k,alpha,(double*)a,lda,(double*)b,ldb,
beta,(double*)c,ldc);
and try the test again.
For example, with your data I have:
a matrisi
1.20 1.20 1.20 1.20
1.20 2.20 3.20 4.20
b mmatrisi
0.50 0.50 0.50
0.50 1.50 2.50
0.50 2.50 4.50
0.50 3.50 6.50
a*b matrisi
2.400000 9.600000 16.800000
5.400000 26.600000 47.800000
Press any key to continue . . .
a matrisi1.20 1.20 1.20 1.20
1.20 2.20 3.20 4.20
b mmatrisi0.50 0.50 0.50
0.50 1.50 2.50
0.50 2.50 4.50
0.50 3.50 6.50
a*b matrisi
I hope it will help.
--Gennady
Gennady_F_Intel
alper,
double a[2][4];
double b[4][3];
double c[2][3];
int lda=4;
int ldb=3;
int ldc=3;
a matrisi
1.20 1.20 1.20 1.20
1.20 2.20 3.20 4.20
b mmatrisi
0.50 0.50 0.50
0.50 1.50 2.50
0.50 2.50 4.50
0.50 3.50 6.50
a*b matrisi
1.20 2.20 3.20 4.20
0.50 1.50 2.50
0.50 2.50 4.50
0.50 3.50 6.50
a*b matrisi
--Gennady
Alper_Basturk
Thanks for your kindly interest.
Alper Basturk
petr_gamov
excelent, I had the same problem but you saved me.
Petr
