Incorrect result with both FFTW and MKL FFT
vahid_a_
Hello everyone,
I've noticed that both MKL FFT and FFTW is giving me a wrong result while calculating 2D complex-to-complex BACKWARD FFT. I am attaching the source codes that I used on this forum to discuss it with the experts.
While the input array is :
 1.0+0.0i  1.0+0.0i  1.0+0.0i
The forward transform should be:
 9.0+0.0i  0.0+0.0i  0.0+0.0i
 0.0+0.0i  0.0+0.0i  0.0+0.0i
And the backward transform should be again the initial array. However, it is:
 9.0+0.0i  9.0+0.0i  9.0+0.0i
I attached my test code here. Could you pls. let me know why this is happening?
Zhen_Z_Intel
Hi vahid,
If you would like get inverse of forward, you have to set backward scale factor. For you case, please set bscale to 1.0 / real(L(1)*L(2)), the result would be correct. For 1D, make sure fscale*bscale=1/len. For 2D, make sure fscale*bscale=1/ (col*row). If you would like to get similar matlab result for forward & backward, please set fscale=1/col, and bscale=1/row.
Fiona
vahid_a_
I have noticed that there is a scale factor (\sigma) in the original formulation of Discrete Fast Fourier (DFT) approach as it is implemented in Intel MKL here:
https://software.intel.com/en-us/mkl-developer-reference-c-fourier-transform-functions
In the above example array, we need to divide the array to some scaling factor to obtain the exact initial array. How should we access to the value of the (\sigma) or the scaling factor?
Point 1: It seems that the scaling factor is "1" when it is the forward transform. However, it changes during the backward transform.
Point 2: The implemented FFT formulation in MATLAB does not include any scaling factor!
Zhen_Z_Intel
Hi vahid,
Fiona
