- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
I am working with spblas. My matrix dimension is about 300k, nnz is between 2^31 and 2^32-1. To keep the memory consumption as small as possible. I would like to use 32bit unsigned integer to index my element. Is it possible to do so with LP64 by defining MKL_INT as uint32_t? I tried it, but my program crashed with a segmentation fault when calling mkl_scsrmv.
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Changing the definition on your end will not change what MKL is expecting with LP64 defined.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I agree with this. Simply changing your include file doesn't modify the libraries or change the basic mechanism, which doesn't support unsigned indexing in a useful manner.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
TimP (Intel) wrote:
Quote:
Henrik Arlinghauswrote:Changing the definition on your end will not change what MKL is expecting with LP64 defined.
Thanks for the reply! So is there a way to get around this without making the indexing array to be 64bit because it is going to double the size? I tried compiling my program with ilp64 and define MKL_INT as uint32_t, but it did work either.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Sergey Kostrov wrote:
>>...To keep the memory consumption as small as possible. I would like to use 32bit unsigned integer to index
>>my element...Your input matrix is already big and I don't think that you will be able to save a significant amount of memory. Modern operating systems use Virtual Memory ( VM ) and why wouldn't you increase VM settings ( I mean Initial and Maximum sizes ) instead? It is Not clear on what platform and hardware you're going to do processing and please provide details if it is possible.
Sorry for the confusion. I am working on a Linux 64bit machine. If I make the array element a type of 64bit integer, it will double the memory consumption and exceed my physical memory allowance.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
