Inspector Executor COO
Mohammad_A_
I tried Inspector Executor using CSR storage format and it is fine. But when I tried the COO version, I get
SPARSE_STATUS_NOT_SUPPORTED error, in the mkl_sparse_optimize function. Here is a my code:
//Get COO Arrays
//IF you need the implementation of this function I can provide it, I can sort based on column or row used both same error
    ExtractCoo(argv[1], &nr, &nc, &nnz, &rows, &columns, &A);
    float * x = (float*)malloc(nc * sizeof(float)),
        *y = (float*)malloc(nr * sizeof(float));
    //3) Prepare X Array
    for (int i = 0; i < nc; i++)
        x = static_cast <float> (rand()) / static_cast <float> (RAND_MAX);
CALL_AND_CHECK_STATUS(
            mkl_sparse_s_create_coo(&cooInternal, SPARSE_INDEX_BASE_ONE, nr, nc,nnz, rows, columns, A),
            "Error in csrCreate \n");
            mkl_sparse_set_mv_hint(cooInternal, SPARSE_OPERATION_NON_TRANSPOSE, martixDescription, runs),
            "Error after Sparse Hint \n");
 mkl_sparse_set_memory_hint (cooInternal, SPARSE_MEMORY_AGGRESSIVE);
            mkl_sparse_optimize(cooInternal),
            "Error after MKL_SPARSE_OPTIMIZE \n"); // Here I get an error
 // Cold Start
mkl_sparse_s_mv(SPARSE_OPERATION_NON_TRANSPOSE, 1, cooInternal, martixDescription, x, 0, y);
 for (int i = 0; i < runs; i++)
            stime = dsecnd();
            etime = dsecnd();
            runResults = (etime - stime);
So what am I doing wrong ?
Mohammad Almasri
Gennady_F_Intel
All is ok with this case, the problem is not all optimizations are implemented into the current version. We will improve that into one of the future updates. --regards
Alexander_K_Intel2
Currently computational routines operate on a matrix handle that stores a matrix in CSR or BSR formats. Other formats should be converted to CSR or BSR format before calling any computational routines. So i recommend to call mkl_sparse_convert_csr before optimization phase
Alex
