Installation Error
hacretnate_com
I got the "l_mkl_p_10.0.1.014.tgz". but It showed errors such as following
Would you like to install the following?
Intel Math Kernel Library 10.0 Update 1 for Linux*
to continue, or x to exit:
Extracting... ######################################################################################### [100%]./.././install/install: line 1673: 7470 Segmentation fault "$temp_dir/$installer" --installdata "$temp_dir/installdata" $0 "$temp_dir" "$dashfix" "$nonrpm" "$@"
Installation is complete:
Thank you for using Intel Software Development Products, tools for improving application performance.
What am I doing wrong?
Please help me.
Gennady_F_Intel
Hi, I couldn't find your name into intel registration center.
Which License Type ( EVAL, COM, Beta or etc ) do you have?
--GIF
Nikolay_L_Intel
Could you take a look in /tmp/install_temp. directory (please select it based on date)? Does it contain MKL rpm file?
If yes: please install it manually with: rpm -i
If no:
- please try to extract rpm file from the package: /install/install --extract
- installrpm extracted filemanually with: rpm -i /
Please contact forum again if it does not help, I'll think about another workaround.
Please also specify some log data to invesigate issue:
- machine information: uname -a
- distrubitive: cat /etc/*issue
- MKL package name
Thank you,
- Nikolay
Gennady_F_Intel
Hi, are you still experiencing the problem you submitted?
Please let us know if the problem wasnt resolved. In this case, please, look at another
document describes common errors and alternative methods for installing Intel MKL and Intel IPP on various Linux* distributions: Linux* Installation Options
http://software.intel.com/en-us/articles/mkl-ipp-linux-installation-options/
--gif
