Intel MKL 7.0 crashes Microsoft Excel 2000
mciobanu
Hello all!
I should start saying I am a new user of Intel MKL 7.0.
I am trying to create a dll
(callable from Microsoft Excel 2000) that exports a function called func_pow_MKL. This function makes a call to one of the functions inside VML library, namely vdPowx.
Well, this is the implementation:
#include "mkl_vml.h"
double _stdcall func_pow_MKL(double x, double y) {
double arr1[1];
double arr2[1];
arr1[0] = x;
vdPowx(1, arr1, y, arr2);
return arr2[0];
I am using Visual Studio 6.0 on a machine with Windows 2000 operating system.
The Visual C++ project links to mkl_s.lib library. Also, I have included MKL_VML_STDCALL preprocessor identifier.
In an Excel Workbook, I have the following function declaration (in the VBA code):
Public Declare Function func_pow_MKL _
Lib "MKL_Test.dll" _
(ByVal x As Double, ByVal y As Double) As Double
The problem I have is Excel crashes every time I call func_pow_MKL function. While trying to debug my function I noticed that func_pow_MKL crashes whenever vdPowx(1, arr1, y, arr2); line is executed.
If I create a Win32 Console application (i.e. a simple exe program) func_pow_MKL works as expected. Also, if I comment vdPowx(1, arr1, y, arr2); line, Excel does not crash.
Any suggestions in how to use Intel MKL when implementing functions that are going to be used in Microsoft Excel?
Just in case, I have attached the Excel Workbook "MKL Test Wkbook.xls", as well as the files used in creating my test dll (MKL_TEST.dll). Change cell C6 (from MKL Test Wkbook.xls!Sheet1) to "=func_pow_MKL(C3,C4)" and you will get a beautiful Excel.exe - Application error message box... (however, before you try this, inside "MKL Test Wkbook.xls" vba's code, update "C:YourFolderHereMKL_Test.dll" to the proper path...)
Manuel C.
