Intel MKL CBLAS compatibility?
tcscott
Hello
I am new to this forum and so my apologies in advance if these questions have been raised before.
I recall that the earlier versions of the MKL library required the Intel compiler.
Questions:
1) Can the Intel MKL library be used with the GNU C/C++ compiler?
2) Will it also work on a virtual machine (vmware) if an Intel chip is supporting the virtual machine?
Thanks in advance for any info.
best wishes
Tony
ArturGuzik
Valued Contributor I
as far as (1) goes, answer is yes.
A.
