7302 Discussions
Intel MKL (CBLAS) doesn't support more than 8 processors. Is it true ?
yuryserdyuk
Hi !
I have machine with 2 Intel Xeon CPUX5570 processors. So the number of logical cores is 16.
NowI am trying to perform
[cpp]mkl_set_num_threads ( P );
cblas_sgemm(CblasRowMajor, CblasNoTrans, CblasNoTrans, N, N, N, 1.0, A, N, B, N, 0.0, C, N );  [/cpp]
Then for P > 1 and P <= 8 and P odd, program is executed on P - 1 processors.
For P > 8, program is executed always on 8 processors.
How to force program to use more then 8 processors ?
MKL Version used 10.2.4.032.
TimP
Did you refer to previous discussions about how MKL uses 1 thread per core, unless you over-ride the default, in order to avoid accidental performance reduction?
Gennady_F_Intel
Yury,
please try to change MKL_DYNAMIC variable:mkl_set_dynamic( FALSE ). See more details into User's Guide. Please pay attention - in this case you may have performancedegradation.
--Gennady
yuryserdyuk
Yes, you are right - mkl_set_dynamic helps, but the results degradate considerably:
N
cblas_sgemm (8 proc)
cblas_sgemm(16 proc)
cuBLAS(Tesla 1060 GPU)
8192
6,06
7,26
2,71
10240
11,72
13,90
5,26
12288
20,23
24,32
9,07
14336
32,16
38,06
14,37
16384
48,46
58,80
21,42
18432
68,59
82,60
30,46
N is a matrix size, and time is given in seconds.
So, obviously, Intel MKL doesn't scale more than 8 processors on processors with Hyper-Threading ...
The same picture is observed for cblas_dgemm function ...
Gennady_F_Intel
This is an expectingbehaviorof Intel MKL. We don't recommend use HT enabled with this case.
Please read more about into UserGuide "The use of Hyper-Threading Technology".
--Gennady
TimP
That section is in the user guide, found in the Documentation/en_us/mkl/ directory of the compiler installation, page 6-16. It can't be found by the search function in Adobe.
In short, as MKL schedules the floating point adder and multiplier to full effectiveness when running 1 thread per core, and the hyper-threads share the paths to higher level cache and memory, the interference effect of additional threads should not be a surprise.
