Intel MKL bug?
TomasU
I might have found a bug in Intel MKL BLAS library (cblas_daxpy). I have 100.000+ line multithreaded+openmp C++ software project. It uses BLAS functions for linear algebra. The version number of Debian's MKL is 2020.4.304-4.
When running multithreaded reinforcement learning code, the Intel MKL gives wrong result in certain scalar*vector code (the neural network code seem to work fine).  I updated to g++ 14 but it doesn't fix the problem. When I switched to OpenBLAS (slower) the results are again correct.
Now it is possible to have race condition or memory access errors in the complex multithreaded code. When I ran valgrind and gcc's sanitizers, I fixed many small problems in the code but there might still be  errors in the actual code and not in MKL.
TomasU
I updated to Intel MKL 2024.1.0-691 (oneapi-mkl debian package) and now it works correctly also with MKL.
So there might have been a bug in the earlier MKL versions but updating solved the problem
Gennady_F_Intel
Tomas, thanks for letting us know, but actually we didn't see such daxpy related problem the last 5 years. Is it possible to get us the reproducer to check this case on our end?
TomasU
Then it is likely there is some bug in my project.
I’m now implementing/testing new features (it seems reinforcement learning I’m using don’t work well enough, at least yet). Once features have been tested to function, I will start seriously fixing bugs and probably send you code to reproduce the error if there is error in the MKL.
Gennady_F_Intel
Ok, thanks for letting us know. This thread is closing. In the case if you will build the right reproducer, you might open the new forum thread.
-- Gennady
