7298 Discussions
Intel® Math Kernel Library 11.2 Update 4 is now available
Gennady_F_Intel
Intel® Math Kernel Library (Intel® MKL) is a highly optimized, extensively threaded, and thread-safe library of mathematical functions for engineering, scientific, and financial applications that require maximum performance. Intel MKL 11.2 Update 4 packages are now ready for download. Intel MKL is available as part of the Intel® Parallel Studio XE 2015 . Please visit the Intel® Software Evaluation Center to evaluate this product.
Intel® MKL 11.2 Update 4 Bug fixes
What's New in Intel® MKL 11.2 Update 4 : Release Notes
Wei_Z_Intel
Hi Gennady,
        Thank you for the MKL 11.2 update, I am using it, but meet an issue, I tried many suggestions from posts, but none of them worked, so ask for help here.
        Below is the issue I meet.  I'm trying to use MKL Vector Mathematical Functions like vcMulByConj etc as below as an example(did not do input buffer initialization here, just an example).
void mklFuncTest()
 MKL_Complex8 inputPtr1[100];
 MKL_Complex8 inputPtr2[100];
 MKL_Complex8 outputPtr[100];
 MKL_INT numData = 100;
 //call mkl function
 vcMulByConj(numData, inputPtr1, inputPtr2, outputPtr);
    return;
      When I run the code, for win32 platform, it builds and runs both fine, but for x64 platform, when it goes to vcMulByConj, it fly, by going to dissembly, I see it fly when running below code
000000013FB74A6F  call        mkl_vml_serv_load_vml_dll (013FB761F0h)
     It looks to me that it could not run well with lib/dll 'mkl_vml_serv_load_vml_dll' on x64 platform.  Building is ok, looks that lib/dll is there.
    And I see, some of other MKL functions can run well like FFT(DftiComputeForward) etc on x64 application.
      I am using below version of tools:
        parallel_studio_xe_2015
        w_mkl_11.2.1.148
        w_ipp_8.2.1.148
        Visual Studio professional version 2013
    Per my understanding,  I used automatical link to MKL via property->Intel Performance Library->use intel MKL->Parallel, in  property->Linker->Advanced->Target Machine, I set to MachineX64 (/MACHINE:X64).  For Linker->Input->Additional Dependance, I keep it unchanged.
     My PC info is as below:
         Processor: Intel core i5-3320M CPU
         System Type: 64-bit Operation system
John
