7303 Discussions
Intel oneAPI Math Kernel Library (oneMKL) version 2025.0 is released.
Ruqiu_C_Intel
Soeren_L_
Dear Ruqiu_C_Intel,
thank you very much for the information.
Will be there also a 32 Bit Version available like in the past e.g. the w_BaseKit_32bit_p_2024.0.0.49184_offline.exe for the Version 2024.0.0?
Soeren
Ruqiu_C_Intel
Dear Soeren,
There isn't 32-bit anymore in new oneMKL versions. There was a deprecation for removing oneMKL 32-bit in oneMKL 2023.2 release notes here: https://www.intel.com/content/www/us/en/developer/articles/release-notes/onemkl-release-notes-2023.html#inpage-nav-2-2
Deprecations
  • As the industry has largely shifted to 64-bit architecture over the last decade, Intel® oneMKL 32-bit binaries will be deprecated in the upcoming Intel® oneMKL 2024.0 release and targeted to be removed after one year deprecation notice period
Ruqiu
Soeren_L_
Dear Ruqiu,
thanks a lot for this information.
That means also security vulnerability fixes for older 32 Bit Versions  (e.g. 2024.0.0) will not be available any more or is there still a chance to get them?
Soeren.
Ruqiu_C_Intel
Dear Soeren,
oneMKL 2024.2 was the last 32-bit version as statement in oneMKL 2023.2 release notes here: https://www.intel.com/content/www/us/en/developer/articles/release-notes/onemkl-release-notes-2023.html#inpage-nav-2-2.
Older version does not include optimizations for newer CPU instructions, which means it may not be delivering the best possible performance for your system. We strongly recommend upgrading to the latest version of the product. The new version has been optimized for modern hardware and includes important security patches.
If have you already registered oneAPI license, then you can download newer version through Intel Registration Center before the end of your current support period.
For Purchase, Renew, and Upgrade questions, please visit FAQ.
Any priority support, please submit a support ticket through Online Service Center. Also, attached the guidance about How to Create a Support Request
Ruqiu
murat77
SGESDD error for large matrices in MKL. I am getting error :Intel oneMKL ERROR: Parameter 12 was incorrect on entry to SGESDD. However I don't get any error for LAPACKE_dgesdd. Example code:
int main() {
const MKL_INT m = 10000, n = 7000;
const MKL_INT lda = n; // 700 for row-major
const MKL_INT ldu = n; // 700 for row-major economy U
const MKL_INT ldvt = n; // 700 for row-major economy V^T
// Use vectors on the heap to avoid big arrays on the stack
std::vector<double> AD(m*n), UD(m*n), VTD(n*n), SD(n);
// Fill A with random values
std::random_device rd;
std::mt19937 gen(rd());
std::uniform_real_distribution<double> distD(0.0f, 1.0f);
for (auto &val : AD) val = distD(gen);
// Compute SVD
lapack_int info = LAPACKE_dgesdd(
LAPACK_ROW_MAJOR, 'S',
m, n,
AD.data(), lda,
SD.data(),
UD.data(), ldu,
VTD.data(), ldvt
if (info > 0) {
std::cerr << "The algorithm computing SVD failed to converge.\n";
return 1;
print_matrix<double>( "Singular values", 1, n, SD.data(), 1 );
std::vector<float> A(m*n), U(m*n), VT(n*n), S(n);
std::uniform_real_distribution<float> dist(0.0f, 1.0f);
for (auto &val : A) val = dist(gen);
// Compute SVD
info = LAPACKE_sgesdd(
m, n,
A.data(), lda,
S.data(),
U.data(), ldu,
VT.data(), ldvt
if (info > 0) {
return 1;
print_matrix<float>( "Singular values", 1, n, S.data(), 1 );
// Output singular values, etc.
return 0;
