Invalid read of size 4 in mkl_serv_malloc
erling_andersen
We have a crash in MKLon Intel 64x86 using Intel 13.1.3. It is both from valgrind and gdb. We use
     mkl_disable_fast_mm();
So it seems the buffer stuff should never be allocated.  Well, I am not sure but the buffer stuff seems in use.
Any suggestions, comments?
[My application which is a .so linked with a static version version of MKL into a MATLAB mex file. A MATLAB mex file is also a so it is called from MATLAB. Now MATLAB is is linked with MKL but another version and the shared lib. The crash above only pops up if called from MATLAB. Maybe this is a special situation you have not considered.]
The stacj trace should come here but your spam filer prevented me from adding it.
erling_andersen
I cannot paste the stack trace becuse of the spam filer but it is attached
erling_andersen
We are using   composer_xe_2013.5.192
Dmitry_B_Intel
Could you print and paste here the parameters you pass to cblas_dgemm in MSK_INTEL_P4_mathenv_gemm (mathenvcpu.c:2293) ? That would help us to reproduce the issue.
Dima
erling_andersen
I have spend more time rsearching the issue. It seems
  • The problem is independent of the matrix sizes.
  • The problem occurs in the first call to dgemm. I moved the call to dgemm to begning of my program. To reduce the risk I overwrote the your data. It still occurs.
So the problem seems to be related to initialization of perhaps your intial data structures. Does that help. We link static as I mentioned.
I might be able to create an example but it will require you can run MATLAB r2013a on linux64x86. Is that of interest?
erling_andersen
I also tried linking with  libmkl_sequential.so and then the problem also goes away.
However, I REALLY HATE that solution because distributing more shared libraries is a major PAIN. Also I had to set LD_PRELOAD to get it working which is major PAIN too.
erling_andersen
I have reported a test case in  http://software.intel.com/en-us/forums/topic/486842
Chao_Y_Intel
Thanks.  I will check in that one.
