7303 Discussions
Inverting a fully populated, low dimension square matirx
Ahmad_Falahatpisheh
Dear All,
Could someone kindly give me an example for C++ which uses MKL library for calculating the inverse of a square matrix. I would like to extend that to find the inverse of a square matrix which is fully populated and low dimensions (at most 2020).
Ahmad
Ahmad_Falahatpisheh
I have found the example at http://stackoverflow.com/questions/3519959/computing-the-inverse-of-a-matrix-using-lapack-in-c. However, the function dgetrf and dgetri are not fast. I compared the speed for calculating the inverse of 1010 fully populated matrix with MATLAB and there was order of magnitude difference. Is there a faster function than dgetri?
styc
How fast do you want it to be? By my measurement DGETRF + DGETRI takes just 1.8ms:
$ cat test.f90
program test
    double precision a(10, 10), work(10)
    integer ipiv(10), info
    integer t1, t2, r
    call random_number(a)
    call system_clock(count=t1)
    call dgetrf(10, 10, a, 10, ipiv, info)
    call dgetri(10, a, 10, ipiv, work, 10, info)
    call system_clock(count=t2, count_rate=r)
    print *, (t2 - t1) / sngl
end program
$ ifort test.f90 -otest -mkl=sequential
$ time ./test
 1.8000000E-03
