Is MKL 1D FFT multi-threading?
Filippo_Spiga
Dear all,
I have tried to check my problem settinb OMP_NUM_THREAD and after MKL_NUM_THREAD more than 1 but nothing seems to be happen. In my program I create a descriptor for 1D FFT
status = DftiCreateDescriptor( &Desc_Handle, DFTI_DOUBLE, DFTI_COMPLEX, 1, n );
and after I call
status = DftiComputeForward( Desc_Handle, y );
Computation is correct, I check the results at the end. but is 1D FFT inside MKL library multi-thread?
Gennady_F_Intel
Quoting - Filippo Spiga
Dear all,
and after I call
it depends on the verision of MKL you are using and the size of the problem you are running on
--Gennady
Filippo_Spiga
--Gennady
Interesting. Can you give me some details?
I have the possibility to use two different version of MKL
- Intel MKL 10.0
- Intel MKL 10.0 Update 2
and my problem size varies between 256 to 8388608 (2^23).
Cheers
Dmitry_B_Intel
Hi Filippo,
It is in-place transform (the default) that is not threaded in this version.
Will out-of-place transform go for your needs?
Dima
Filippo_Spiga
Hi Filippo,
Dima
I will try setting the placement ad OUT-OF-PLACE. But, there is a way to check that the computation is really made in a multi-threaded way?
Dmitry_B_Intel
Environment variable KMP_AFFINITY containing option 'verbose' will report to you about threading. Hope this helps.
Dima
Gennady_F_Intel
- Intel MKL 10.0
Cheers
Filippo,
just as an additional info: add the link to the where you can find the document describes the cases for which the Intel MKL 10.2 and later 1D complex-to-complex FFTs are threaded.
"Intel MKL Threaded 1D FFTs"
--Gennady
