Is MKL geo-dependent library?
dmitry_k
I use MKL from C++ Compiler 11.1.054 Professional Edition for Windows package. I used vdCos function. When I try to run my application at Windows XP with Russian region standards settings it crushed with message:
OMP: Warning #2: Cannot open message catalog "1049\\libiomp5ui.dll":
OMP: System error #126: .
OMP: Info #3: Default messages will be used.
If I change region standards to US English, then application works good. Test case is very simple:
#include "mkl.h"
#define N 10000
int main(int argc, char **argv)
int i = N;
double arg,res;
for(i = 0; i
arg = 0.01*i;
vdCos( N, arg, res );
return 0;
Gennady_F_Intel
Dmitry,
Please check the latest Update of Intel C++ Compiler Professional Edition ( v 11.1 Update 6) or the standalone version of MKL ( 10.2 Update 5). The problem should be fixed in these updates.
--Gennady
Gennady_F_Intel
Dmirty,
This is well known problem.Please see this KB article, I hope it will help you to find out the appropriate workaroudns.
--Gennady
dmitry_k
Hello, Gennady
Thank you for timely answer. I saw there a lot of complains of community's members. I believe that issue isn't difficult to fix but we don't see progress on that side. Can you tell us when fix is expected? May be Intel's authority can provide that info to us.
Thank you,
Dmitry
Gennady_F_Intel
Dmitry,
--Gennady
