7287 Discussions
Is it possible to evaluate an older version of MKL?
robkal
Hello all,
I am trying to build the quantum chemistry program Gaussian on a new machine. I would like to use Intel compilers, but require libmkl_ipf.a which is no longer distributed in the current versions of the MKL.
Many thanks.
TimP
Quoting - robkal
You may do better to modify your link script in accordance with the link advisor in the right hand column of the header page for this forum, so you can use the MKL which matches current compilers. If you have an evaluation license for MKL, and register it at https://registrationcenter.intel.com, you should be able to download old versions.
Gennady_F_Intel
Quoting - tim18
here are the steps to download older version of products from the the registration center:"article"
and for your reference, please see the following articles about :"New in Intel MKL 10.2"
and Known Limitations in Intel MKL 10.2.
