7298 Discussions
Is there any way to use VML on 2-dimensional array?
王__云飞
Suppose I have a 2-dimensional array a,and I want to get the result array of  one row of a adding another row of a.Is there any way to use VML in this case?I‘ve tried to directly use the code like this : vdAdd( n, a[1], a[3], y_add ),but errors comes.
If VML can't support 2D array, is there any other libraries which could support calculate between 2D arrays?
Andrey_G_Intel2
you question mostly relay to other question "how to work with pointer in C". Hope my small example will help you.
#include <stdio.h>
#include "mkl.h"
#define DIMX 10
#define DIMY 2
main()
    double a[DIMY][DIMX],y[DIMX];
    int i,j;
    for(i=0;i<DIMX;i++)
        ((double *)(a))=i;
        ((double *)(a))[i+DIMX]=i+DIMX;
        y=-1;
    for(j=0;j<DIMY;j++)
        for(i=0;i<DIMX;i++)
            printf("%.2f  ",a);
        printf("\n");
    vdAdd(DIMX,(double *)a,&((double *)a)[10],y);
    for(i=0;i<DIMX;i++)
        printf("%.2f  ",y);
王__云飞
Thank you!
I also wonder that if I want to offload only the vdAdd line to the MIC,what should I claim before the line?
I thought it may be like this:
#pragma offload target(mic:0)in((double *)a,&((double *)a)[10]:length(DIMX)) inout(y_add:length(DIMX))
However,it doesn't work.
Could you help me with this?
