Issue with DESCINIT in Scalapack
OP1
New Contributor III
There is an issue with calls to DESCINIT in some circumstances. The program below illustrates the problem. As is, the program implements a manual workaround and will complete successfully. To exhibit the buggy behavior of DESCINIT, uncomment the three lines of the code that are identified as problematic.
PROGRAM SCALAPACK_DEMOS
IMPLICIT NONE (TYPE, EXTERNAL)
! The intent of this program is to scatter a 2x2 matrix A
! defined on 1 process (1x1 BLACS process grid with context CONTEXT_A)
! to local 1x1 matrices B on 4 processes (2x2 process grid with context CONTEXT_B),
! using the scalapack routine PDGEMR2D.
! This program must be run as 4 processes/images.
! Appropriate linking to Blacs/Scalapack is necessary.
INTEGER, PARAMETER :: DP = SELECTED_REAL_KIND(15, 307)
EXTERNAL :: &
    BLACS_GET, &
    BLACS_PINFO, &
    BLACS_GRIDINIT, &
    DESCINIT, &
    PDGEMR2D
INTEGER :: SYSTEM_CONTEXT, CONTEXT_A, CONTEXT_B ! BLACS CONTEXTS
INTEGER :: MY_PROC, N_PROCS ! BLACS DATA
INTEGER :: INFO ! SCALAPACK RETURN VALUE
INTEGER, DIMENSION(9) :: DESC_A, DESC_B ! MATRIX DESCRIPTORS
REAL(KIND = DP) :: &
    A(4), & ! Matrix to be scattered with meaningful values only on 1 process
    B(1)   ! Space for local matrix on a 2x2 process grid after scatterinng
CALL BLACS_GET(-1, 0, SYSTEM_CONTEXT) ! Get the BLACS System Context
CALL BLACS_PINFO(MY_PROC, N_PROCS) ! Determine my process number MY_PROC and the number of processes N_PROCS in machine
IF(N_PROCS /= 4) STOP ! Ensure code is being called with 4 processes
CONTEXT_A = SYSTEM_CONTEXT
CALL BLACS_GRIDINIT(CONTEXT_A, 'R', 1, 1) ! Initialize context for A with 1x1 process grid
CONTEXT_B = SYSTEM_CONTEXT
CALL BLACS_GRIDINIT(CONTEXT_B, 'R', 2, 2) ! Initialize context for B with on a 2x2 process grid
B = -77.7_DP  ! Assign garbage at locations where A will be scattered to
CALL DESCINIT(DESC_B, 2, 2, 1, 1, 0, 0, CONTEXT_B, 1, INFO) ! Descriptor for B
IF (CONTEXT_A /= -1) THEN
    A = [1.1_DP, 2.2_DP, 3.3_DP, 4.4_DP] ! Value on process in CONTEXT_A which to be scattered
ELSE
    A = -999.0_DP ! Not a processes in CONTEXT_A. Assign garbage values
END IF
! Create DESC_A
! Issue is below :
! The IF/ELSE below should not be necessary.
! Instead it should be possible to call DESCINIT directly on all processes.
! However if we try to do this we will get an error with INFO = -6 for processes not in CONTEXT_A.
! An error is issued internally because CONTEXT_A = -1 on those processes.
! But later PDGEMR2D demands DESC_A have -1 for context. So we have to create DESC_A manually.
! Uncomment the lines below to trigger the error above:
!CALL DESCINIT(DESC_A, 2, 2, 1, 1, 0, 0, CONTEXT_A, 2, INFO)
!WRITE(*,*) 'INFO for DESC_A ON PROC ', MY_PROC, ' = ', INFO
!STOP
IF (CONTEXT_A /= -1) THEN ! Fill only on master
ELSE
    DESC_A = -2 ! Garbage value. Only entry for context matters on these processes
    DESC_A(2) = -1 ! Context
END IF
! Scatter 2x2 A on 1 process to local 1x1 B's on 4 processes
CALL PDGEMR2D(2, 2, A, 1, 1, DESC_A, B, 1, 1, DESC_B, CONTEXT_B)
SYNC ALL
WRITE(*,*) 'B on ', MY_PROC, ' = ', B(1)
END PROGRAM SCALAPACK_DEMOS
Aleksandra_K
Thank you for reporting the problem. I reproduced the issue and we will work on it internally. I'll update you here with any news.
Alex
Aleksandra_K
The presented behavior is actually expected. If the current process is out of scope of the input context, it reports an error, see the reference implementation of the ScaLAPACK (netlib.org/scalapack/tools/descinit.f).
Alex
Aleksandra_K
Do you have any further questions on the topic or is everything clear?
Alex
Aleksandra_K
If you have any follow-up questions, please let us know. In case of no response within three days, this thread will no longer be monitored by Intel.
OP1
New Contributor III
@Aleksandra_K Thanks for clarifying the use of descinit! You may close this thread now.
