Issue with Intel OneAPI MKL PARDISO
Jeremie_V_
Dear,
Using ifort 2021.2.0, MKL Pardiso provides a wrong answer when a permutation vector is provided, while it provides a correct answer when no permutation vector is provided.
The correct answer is computed in both cases with Intel ifort 17.0.0
I checked the API, but it doesn't seem that it changed since ifort 17.0.0
I wonder if the problem is in my code, or in the library.
Attached is a small program that reproduces the issue.
In advance thank you.
Jeremie
```fortran
include 'mkl_pardiso.f90'
program test
use iso_fortran_env, only: int32, real64, output_unit
use mkl_pardiso, only: MKL_PARDISO_HANDLE
implicit none
integer(int32), allocatable :: crs_i(:), crs_j(:)
integer(int32), allocatable :: perm(:)
integer(int32) :: getdim
real(real64), allocatable :: crs_a(:)
real(real64), allocatable :: rhs(:), x(:), x_true(:)
logical :: lperm = .true.
!Pardiso variables
integer(kind=int32) :: i, error
integer(kind=int32)::nrhs
integer(kind=int32)::idum(1)
real(kind=real64)::ddum(1)
integer(kind=int32)::maxfct
integer(kind=int32)::mnum
integer(kind=int32)::mtype
integer(kind=int32)::msglvl
integer(kind=int32)::phase
integer(kind=int32)::solver
integer(kind=int32),allocatable::iparm(:)
type(MKL_PARDISO_HANDLE),allocatable::pt(:)
crs_i = [1, 4, 6, 7, 8, 9]
crs_j = [1 , 2 , 3 , 2 , 3 , 3 , 4 , 5]
crs_a = [10._real64, 1._real64, 1.2_real64, 10._real64, 0.3_real64, 13.4_real64, 0._real64, 1._real64]
rhs = [1._real64, 2._real64, 3._real64, 0._real64, 5._real64]
x_true = [5.543360619502753d-002, 0.188015426594107_real64, 0.214707092879682_real64&
,0._real64, 5._real64]
allocate(x, mold = rhs)
perm = [3, 2, 1, 5, 4]
getdim = size(crs_i) - 1
call printsquare(crs_i, crs_j, crs_a)
! print*,getdim
! print*,crs_i
! print*,crs_j
! print*,crs_a
! print*,rhs
maxfct = 1
mnum = 1
mtype = -2
solver = 0
msglvl = 1
nrhs = 1
idum = 0
ddum = 0
allocate(iparm(64))
iparm = 0
allocate(pt(64))
do i=1,64
pt(i)%dummy = 0
enddo
call pardisoinit(pt,mtype,iparm)
!Ordering and factorization
phase = 12
iparm(2) = 3
iparm(19) = -1
iparm(24) = 1
iparm(27) = 1
iparm(28) = 0
write(*,'(a)')' Start ordering and factorization'
if(lperm)then
!provide a permutation vector
iparm(5) = 1
iparm(31) = 0
iparm(36) = 0
call pardiso(pt,maxfct,mnum,mtype,phase,&
getdim,crs_a,crs_i,crs_j,&
perm,nrhs,iparm,msglvl,ddum,ddum,error)
else
!don't provide a permutation vector
idum,nrhs,iparm,msglvl,ddum,ddum,error)
endif
call checkpardiso(phase,error)
iparm(27)=0 !disable Pardiso checker
!Solving
phase=33
idum,nrhs,iparm,msglvl,rhs,x,error)
write(*,'(a,*(f10.4,x))')'x = ',x
if(sum(abs(x - x_true))/size(x) > 1.d-6)then
write(*,'(a,*(f10.4,x))')'x_true = ',x_true
print*,'Rel abs error = ',sum(abs(x - x_true))/size(x)
error stop 'WRONG ANSWER FROM PARDISO'
else
print*,'CORRECT ANSWER'
endif
contains
subroutine checkpardiso(phase,error,un)
integer(kind=int32),intent(in)::phase,error
integer(kind=int32),intent(in),optional::un
integer(kind=int32)::unlog
unlog=output_unit
if(present(un))unlog=un
if(error.ne.0)then
write(unlog,'(2(a,i0))')' The following error for phase ',phase,' was detected: ',error
error stop
endif
end subroutine
subroutine printsquare(ia, ja, a)
integer(int32), intent(in) :: ia(:), ja(:)
real(real64), intent(in) :: a(:)
integer :: i, j
real(real64), allocatable :: dense(:,:)
allocate(dense(size(ia)-1,size(ia)-1), source = 0._real64)
do i = 1, size(ia)-1
do j = ia(i), ia(i+1) - 1
dense(i, ja(j)) = a(j)
dense(ja(j), i) = a(j)
enddo
enddo
write(*,'(*(f10.4,x))')dense(:,i)
enddo
end subroutine
end program test
Gennady_F_Intel
Jeremie,
the issue is fixed into the latest MKL 2021.4 which is available for download.
here is the result I see when linked against this update:
$ ./a.out
  10.0000   1.0000   1.2000   0.0000   0.0000
  1.0000  10.0000   0.3000   0.0000   0.0000
  1.2000   0.3000  13.4000   0.0000   0.0000
  0.0000   0.0000   0.0000   0.0000   0.0000
  0.0000   0.0000   0.0000   0.0000   1.0000
Memory allocated on phase 11  -0.0005 MB
Number of non-zeros in L    11
Number of non-zeros in U    1
Memory allocated on phase 22  -0.0001 MB
Percentage of computed non-zeros for LL^T factorization
 81 % 90 % 100 %
x =   0.0554   0.1880   0.2147   0.0000   5.0000
 CORRECT ANSWER
$ echo echo $MKLROOT
echo /opt/intel/oneapi/mkl/2021.4.0
ShivaniK_Intel
We are able to reproduce the issue at our end. We are working on it and will get back to you soon.
Thanks & Regards
Shivani
Gennady_F_Intel
Jeremie,
is that win or lin os?
Gennady_F_Intel
Jeremy,
I checked versions 2018,2019, 2020 and the latest 2021 - everywhere the problem is reproduce. The latest version which works correct is 2017u5. We will investigate the cause of the issue and keep this thread inform with the status.
thanks for the report.
Jeremie_V_
Thank you for the update.
For ifort 2021: Fedora 31 and 33
For ifort 2017: Red Hat
Yours sincerely,
Jeremie
Jeremie_V_
Thank you. Meanwhile, are there any ways to avoid this issue? Maybe with a different combination of options?
Jeremie
Kirill_V_Intel
Hi Jeremie!
There are two temporary workarounds before we release the new version with the fix:
1) set iparm(24)=0 (classic factorization) or 10 (improved two-level factorization).
or
2) if your system is not small, use more than one thread. if your system is small, try to use more than one thread and set MKL_DYNAMIC to false.
I've quickly checked that both ideas worked.
Best,
Kirill
Jeremie_V_
Dear,
Thank you for your answer.
My usual systems are not small in terms of equations, but highly sparse (that is a few million equations).
I will test both options, and come back if needed!
Yours sincerely,
Jeremie
Gennady_F_Intel
Jeremie,
$ ./a.out
 81 % 90 % 100 %
 CORRECT ANSWER
Jeremie_V_
Great! Thank you!
Gennady_F_Intel
This issue has been resolved and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
