7303 Discussions
LAPACK/GETRF: Unresolved external symbol _SGETRF_MKL95@12
pguillerottrane_com
I can't get around this error.
I reference the MKL95_LAPACK module in one of my FORTRAN routines that calls GETRF. In VS 2005, I set the linker depedencies to: mkl_lapack95.lib mkl_solver_sequential.lib mkl_intel_c.lib mkl_sequential.lib mkl_core.lib.
What am I missing?
Philippe
TimP
I guess you may have CVF compatible linkage (e.g. /iface:cvf) set in your build, while you link libraries which don't work with that option.
mecej4
We need to know at least the declarations of the arguments, the modules USEd, and the actual subroutine call in order to diagnose the problem.
If you can provide a small complete example with which one can reproduce the problem, that would be even better.
Vladimir_Koldakov__I
New Contributor III
Hello, Philippe,
tim18 is right. mkl_lapack95.lib provides only cdecl interface and you link cdecl interface library mkl_intel_c.lib.
So you should not use CVF compatible option if you call MKL lapack95 routines.
Vladimir
pguillerottrane_com
That was it !!! Thank you all.
Philippe
