LAPACK95 diagonalization problem
sknepnek
I have installed MKL 8.0 (evaluation version) on my Linux box running Mandrake 10.0 with ifort and icc versions 8.0
I compiled LAPACK95 interface by simply using
make PLAT=lnx32 lib
ifort complined about file source/cgelsd1.f90 line 30
USE MKL77_LAPACK, ONLY: ILAENV => MKL77_ILAENV
A simple change to
USE MKL77_LAPACK, ONLY: MKL77_ILAENV
plus change of line #76
SMLSIZ = ILAENV(9,'CGELSD',' ', 0,0,0,0)
to
SMLSIZ = MKL77_ILAENV(9,'CGELSD',' ', 0,0,0,0)
fixed the probelm, i.e., compilation went smoothy.
However, if I compile examples
make lib32
although the compilation goes witout any problems, the results are wrong.
For example, if you look into syev.res the output looks like:
SYEV Example Program Results
Matrix A:
-5.00000 -3.00000 1.00000 5.00000 3.00000
0.00000 2.00000 -1.00000 4.00000 -1.00000
0.00000 0.00000 6.00000 3.00000 -1.00000
0.00000 0.00000 0.00000 1.00000 -1.00000
0.00000 0.00000 0.00000 0.00000 -7.00000
CALL SYEV( A, W )
W on exit :
-11.24619
-6.24975
1.18524
5.00130
8.30939
Maple gives: 1, 2, -5, 6, -7
Simple inspection showes that -5 has to be an eigenvalue.
