LNK2005 error mkl visual studio
Lin_
When I build with release mode in my project I get those message
error LNK2005: mkl_serv_set_xerbla_interface already defined in mkl_sequtential_dll.lib(mkl_sequential.2.dll)
error LNK2005: mkl_serv_set_default_xerbla already defined in mkl_sequtential_dll.lib(mkl_sequential.2.dll)
fatal error LNK1169:one or more multiply defined symbols found
because when I build with debug mode , it can build successfully
how can i fix this problem?
I only use Direct Sparse Solver in my project
and I build example dss_sym.c both in debug and release mode are successful
PraneethA_Intel
Thanks for posting in Intel communities.
Could you please give us the following details so that we could look into your issue?
  1. Environment Details
  2. Sample Reproducer
  3. Steps to reproduce
Thanks and Regards,
Praneeth Achanta
PraneethA_Intel
We have not heard back from you, could you please provide an update on your issue?
Thanks and Regards,
Praneeth Achanta
PraneethA_Intel
We have not heard back from you, could you please provide the information requested above?
Thanks and Regards,
Praneeth Achanta
