LU factorization of band matrix
baskin
I try to use https://software.intel.com/sites/products/documentation/doclib/iss/2013/mkl/mklman/GUID-03E2AA41-0886-485D-B0D7-1C2186119220.htm routine for band matrix factorization. I've wrote simple application that factorizes 4*4 matrix. However, I can't undertand relation between elements of matrix L and multipliers used during factorization mi,j. Those mutipliers represent correct columns of matrix L, but order of elements mi,j in the column is not correct. I assume, some permutation of rows should be performed based on ipiv vector.
Initial matrix:
-0.230 -6.980  0.000  0.000
 2.540  2.460  2.560  0.000
-3.660 -2.730  2.460 -4.780
 0.000 -2.130  4.070 -3.820
Result of dgbtrf:
 0.000  0.000  0.000 -4.780
 0.000  0.000  2.460  0.300
 0.000 -2.730 -0.155 -3.292
-3.660 -6.808  4.254 -0.727
-0.694 -0.083  0.968  0.000
 0.063  0.313  0.000  0.000
Permutation vector: 3 3 3 4
In this case
m21 = -0.694 m32 = -0.083 m43= 0.968
m31 =  0.063 m42 = 0.313
Those values form matrix L_result:
 1.000  0.000  0.000  0.000
-0.694  1.000  0.000  0.000
 0.063 -0.083  1.000  0.000
 0.000  0.313  0.968  1.000
However, the correct answer is L_correct:
 0.063  1.000  0.000  0.000
-0.694 -0.083  1.000  0.000
Could you explain how L_result should be transformed into L_correct in general case?
Ying_H_Intel
Hi Baskin,
Could you please attach your code and tell which platform you are working?
Ying
baskin
Hi Ying,
Thank you for reply. I have solved my problem. I didn't understand output of gbtrf - the meaning of coefficients mi,j. The explanation is pretty simple. LU factorization with partial pivoting requires swap of rows. For dense matrices, full rows are swapped( i.e columns from 1 to n). In gbtrf routine swap is performed using only "right" part of the row. For example, if you already found 10 columns, at step 11 you are going to swap rows 11 and 16(row 16 contains maximum element), then you should swap elements in row 11 starting from column 11, in row 16 starting from column 11 too. For dense matrix, you would swap elements starting from column 1.
Ying_H_Intel
Hi Baskin,
Thanks for the updating and sharing the result.
Ying
