Lapack functions in MKL
Deleted_U_Intel
I'm using SGEQPF, SORMQR and SPOTRF functions from the Lapack library. I have downloaded and connected the trial version of the Intel MKL (I use mkl_s.lib mkl_lapack.lib mkl_ia32.lib). All BLAS functions (SAXPY, SDOT, etc.) are linked well, but I cannot link SGEQPF, SORMQR and SPOTRF.
Which library should I have for SGEQPF, SORMQR and SPOTRF?
Intel_C_Intel
Depending on the version of MKL you are using you should need to only link mkl_s.lib provided the library directory is on your path, even if set by the linker. I just tried this with the Intel compiler (linking mkl_c.lib) and the program linked properly. In my case I copied exampleslapacksourcesormqrx.f to the lapack directory and executed this line with the associated output:
C:mklMKL6.0exampleslapack>ifl sormqrx.f /link /libpath:....ia32lib ....
ia32libmkl_c.lib liblapack32_intel.lib
Intel Fortran Compiler for 32-bit applications, Version 7.0 Build 20021028Z
Copyright (C) 1985-2002 Intel Corporation. All rights reserved.
EPC Fortran-95 Version F95 Intel:200200:131124
Copyright (c) 1993-2000 EPCL. All Rights Reserved.
sormqrx.f
main program
55 Lines Compiled
Microsoft Incremental Linker Version 6.00.8168
Copyright (C) Microsoft Corp 1992-1998. All rights reserved.
-out:sormqrx.exe
....ia32libmkl_c.lib
sormqrx.obj
Bruce
Intel_C_Intel
From a distance this is difficult to analyze. In this case I would suggest submitting the issue to http://premier.intel.com. You should provide enough code for us to replicate the problem, if possible. It is always possible that there is a problem with the library code and your example may expose that.
Bruce
