Lapack-interfaces and FFT problems
Svein-Atle_Engeseth
I just downloaded the Visual Fortran Composer. I wanted to try it out under Windows 7 and 64 bits.
Lapack problems:
The supplied *.MOD files ( 64 bit ) do not work.
When I compile the BLAS.F90 and LAPACK.f90 the interfaces work.
FFT problems.
I can compile my programs, but when I try running them, I get a message saying the DFTI descriptor is corrupted.
Any suggestions to what the problem might be?
Svein-Atle
Gennady_F_Intel
regarding BLAS and LAPACK95 interfaces:
it might be because of all of these interfaces are compile-dependent.
regarding FFT: can yo provide the example? How do you link? Did you try to build the FFT examples? ( see \examples\dftc\...
--Gennady
barragan_villanueva_
Valued Contributor I
FFT problems.
Could you pleaseprovide us withsmall testcase to reproduce your problem?
