7303 Discussions
Library differences between 10.0 and 10.2
rrinkameslab_gov
Greetings Everyone,
I am trying to get a piece of scientific software to work on a RHEL 3/5 system with the ver 11.1 compiler suite which includes the 10.2 MKL. The scientific software (Wien2K) was last tested with the 10.0.2.018 MKL but we have not been able to get it to link to the 10.2 version. This has been tried with both 32 and 64 bit installs (RHEL 3 and 5 respectively) and failed on both. What I need to know is how the librays changed between the versions so that we can force the program to link to the correct files. I've attached a text file of the failed link libs.
Thanks in advance for the help.
Gennady_F_Intel
Hi,rrink,
-All info about how mkl was changed you can find into 3 Release Notes ( versions 10.1, 10.2 and the latest 10.2 Update2) I attached to this tread.
-Please use the linking adviser tips by following the link:" http://software.intel.com/en-us/articles/intel-mkl-link-line-advisor/". I believe it will enough to resolve all issue you need.
--Gennady
