Linker error with gold
el_samuko
Hi there, when linking MKL with the GNU gold linker, the binaries seem to be broken:
#!/usr/bin/env bash
function cyan {
echo -e "\033[1;34m$*\033[0m"
MKL_DIR="$HOME/intel/oneapi/mkl/latest"
MKL_LIB_DIR="$MKL_DIR/lib/intel64"
MKL_INC_DIR="$MKL_DIR/include"
cat << EOF > demo.cpp
#include <iostream>
#include <string>
#include "mkl.h"
int main() {
std::string buffer(200, '\0');
MKL_Get_Version_String(buffer.data(), 200);
std::cout << buffer << std::endl;
EOF
COMPILER_ARGS="-I"$MKL_INC_DIR" demo.cpp -L"$MKL_LIB_DIR" -Wl,-rpath="$MKL_LIB_DIR" -lmkl_intel_ilp64 -lmkl_intel_thread -lmkl_core -liomp5"
cyan "Without gold:"
g++ $COMPILER_ARGS -o nogold
ldd nogold | grep mkl
./nogold
echo
cyan "With gold:"
g++ $COMPILER_ARGS -fuse-ld=gold -o withgold
ldd withgold | grep mkl
./withgold
echo
cyan "With mold:"
g++ $COMPILER_ARGS -fuse-ld=mold -o withmold
ldd withmold | grep mkl
./withmold
echo
cyan "Without gold, g++-12:"
g++-12 $COMPILER_ARGS -o nogold12
ldd nogold12 | grep mkl
./nogold12
echo
cyan "With gold, g++-12:"
g++-12 $COMPILER_ARGS -fuse-ld=gold -o withgold12
ldd withgold12 | grep mkl
./withgold12
echo
cyan "With mold, g++-12:"
g++-12 $COMPILER_ARGS -fuse-ld=mold -o withmold12
ldd withmold12 | grep mkl
./withmold12
The standard linker and mold do fine, but with gold I get:
With gold:
libmkl_intel_ilp64.so.2 => ~/intel/oneapi/mkl/latest/lib/intel64/libmkl_intel_ilp64.so.2 (0x00007f6b8daa3000)
./withgold: symbol lookup error: ~/intel/oneapi/mkl/latest/lib/intel64/libmkl_intel_ilp64.so.2: undefined symbol: mkl_blas_dgemm
This was tested with the latest MKL "2023.1-Product Build 20230303".
VarshaS_Intel
Hi Samuel,
Could you please try using the below command where we are able to get the expected results using the option "-fuse-ld=gold":
 g++-12 -DMKL_ILP64 -m64 -I"${MKLROOT}/include" demoversion.cpp -o demogold12 -L${MKLROOT}/lib/intel64 -Wl,--no-as-needed -lmkl_intel_ilp64 -lmkl_gnu_thread -lmkl_core -lgomp -lpthread -lm -ldl -fuse-ld=gold
Please find the below screenshot where we have tried using the option -fuse-ld=gold and also without a gold linker.
And also, you can use the tool Intel Link Line Advisor for compiling and linking your code as it is compatible with several compilers and third-party libraries and provides different interfaces to the functionality. Please find the below link for more details:
https://www.intel.com/content/www/us/en/developer/tools/oneapi/onemkl-link-line-advisor.html
Could you please try and let us know if you face any errors?
Thanks & Regards,
Varsha
VarshaS_Intel
Hi Samuel,
Thanks & Regards,
Varsha
el_samuko
Hi Varsha,
thanks for your tipps. The -Wl,--no-as-needed before the libs was enough that ldd printed all libs and the programm could be executed successfully.
I got the command line for the compiler from the MKL included cmake:
find_package(MKL CONFIG REQUIRED)
target_link_libraries(demo MKL::MKL)
Samuel
VarshaS_Intel
Hi Samuel,
Glad to know that you are able to run without errors. Could you please confirm if we can close this case from our end?
Thanks & Regards,
Varsha
el_samuko
Hi Varsha,
for me, yes.
I'd add the -Wl,--no-as-needed to cmake, though, as the link line advisor recommends.
Samuel
VarshaS_Intel
Hi Samuel,
>>for me, yes.
Thanks for the confirmation. Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will
no longer be monitored by Intel.
Thanks & Regards,
Varsha
