7298 Discussions
Linux64bit Numpy 1.6 test_nonsero_byteswap & test failed
vyasd
I am using MKL version 10.3 and Python 2.7.2 and compiled numpy1.6.1 using custom library method.
I ran numpy.test('full') and here is the output.
compiler options used "icc -O2 -g -fPIC -fp-model strict -openmp -xhost "
Couple of tests failed. Has anyone noticed similar problems. Is there a fix for these. These errors don't appear when numpy is compiled with gcc.
test_nonzero_bytesswap
FAIL: test_nonzero_byteswap (test_regression.TestRegression)
Traceback (most recent call last):
File "/home/user/python27-install/lib/python2.7/site-packages/numpy/core/tests/test_regression.py", line 1450, in test_nonzero_byteswap
assert_equal(a.nonzero()[0], [1])
File "/home/user/python27-install/lib/python2.7/site-packages/numpy/testing/utils.py", line 256, in assert_equal
return assert_array_equal(actual, desired, err_msg, verbose)
File "/home/user/python27-install/lib/python2.7/site-packages/numpy/testing/utils.py", line 707, in assert_array_equal
verbose=verbose, header='Arrays are not equal')
File "/home/user/python27-install/lib/python2.7/site-packages/numpy/testing/utils.py", line 600, in assert_array_compare
raise AssertionError(msg)
AssertionError:
(shapes (0,), (1,) mismatch)
x: array([], dtype=int64)
y: array([1])
FAIL: test_kind.TestKind.test_all
File "/home/user/python27-install/lib/python2.7/site-packages/nose/case.py", line 197, in runTest
self.test(*self.arg)
File "/home/user/python27-install/lib/python2.7/site-packages/numpy/f2py/tests/test_kind.py", line 30, in test_all
'selectedrealkind(%s): expected %r but got %r' % (i, selected_real_kind(i), selectedrealkind(i)))
File "/home/user/python27-install/lib/python2.7/site-packages/numpy/testing/utils.py", line 34, in assert_
AssertionError: selectedrealkind(16): expected 10 but got 16
Ran 3552 tests in 52.984s
FAILED (KNOWNFAIL=3, SKIP=1, failures=2)
-thanks,
Vyas
VipinKumar_E_Intel
What libs did you link with? (32 bit or 64 bit)?
--Vipin
vyasd
I linked against 64bit libs. Here is how I generated my custom libs
In tools/builder directory
make libintel64 name=/home/user/libmkl_blas export=blas_example_list
make libintel64 name=/home/user/libmkl_cbals export=cblas_example_list
make libintel64 name=/home/user/libmkl_lapack export=lapack_example_list
barragan_villanueva_
Valued Contributor I
I have some questions related to used MKL libraries.
Quoting vyasd
What exactly custom library was used to link with Numpy? Did you change example-lists?
vyasd
Here is my Numpy 1.6.1 site.cfg
[plain][mkl]
library_dirs = /home/vduggira:/cm/shared/apps/intel/composerxe/2011.5.220/compiler/lib/intel64:/cm/shared/apps/intel/composerxe/2011.5.220/mkl/lib/intel64
include_dirs = /cm/shared/apps/intel/composerxe/2011.5.220/mkl/include
mkl_libs = mkl_blas, mkl_cblas
lapack_libs = mkl_lapack
[/plain]
The example-lists haven't been edited in any way.
(This is numpy 1.6.1, the latest release. Not 1.6 as refered to in the subject line)
thanks,
Vyas
I'd recommend to create the only one custom library (withall needed functions together: blas, cblas, lapack) to be used in site.cfg
