MKL 10.3 Beta: clapack_dgbtrf
brodman
Hi, I'm trying out the 10.3 beta's c support for lapack. I'm having issues with using clapack_dgbtrf with CLAPACK_ROW_MAJOR data layout. My simple example is a 4x4 matrix with 2 upper and lower diagonals, stored in banded form. The main diagonal has hte value 1.1 and the off diagonals have the value -.01.
If I create this matrix using column major layout and call the function as follows:
clapack_dgbtrf(CLAPACK_COL_MAJOR, 4, 4, 2, 2, colA, 7, ipiv);
The following correct result is observed:
x x x x
x x x x
x x -.01 -.01
x -.01 -.0100909 -.0100917
1.1 1.09991 1.09982 1.09982
-.00909091 -.00917431 -.0091754 x
-.00909091 -.00909166 x x
However, if I store the matrix using row major data layout and call the function:
clapack_dgbtrf(CLAPACK_ROW_MAJOR, 4, 4, 2, 2, rowA, 4, ipiv);
I get:
x x x x
x x x x
x x -.01 -.01
1.1 1.09991 1.09982 1.1
-.00909091 -.00917431 -.01 x
-.00909091 -.01 x x
I'm not sure if I'm doing something incorrectly, or whether the code itself might have a < instead of a <= or something....
Edit: When calling the routine with row major layout, the return value is 4.
Any help would be appreciated....
Ying_H_Intel
Hello ~
Could you please attach a small c code for the problem?
If try clapack_dgbtrf(CLAPACK_ROW_MAJOR, 4, 4, 2, 2, rowA, 7, ipiv); what is the return value ?
Ying
brodman
If I change the LDA parameter to 7, it's just completely wrong and returns 1.
The source is attached. I build it with:
icc -O2 -o ultest ultest.cpp -lmkl_sequential -lmkl_core -lmkl_intel_lp64
Gennady_F_Intel
brodman,
your original version was correct. I mean this call:
another words, LDA have to be == 4.
Thanks for the test. I will check the problem on our side and will back asap.
--Gennady
Gennady_F_Intel
Hi Brodman,
This is the error. This issue has been submitted to our internal development tracking database for further investigation, we will inform you once a new update becomes available.Here is a bug tracking number for your reference:
DPD200186873
Regards, Gennady
