7276 Discussions
MKL 2021.4 CoreDump with LAPACKE_cgesvd_work or LAPACKE_zgesvd_work
TonyDelarue
In our code, we encounter a problem. I've isolated it for you.
When you call LAPACKE_cgesvd_work or LAPACKE_zgesvd_work, you may encounter a segfault.
But the case is very specific. You have an example below.
It occurs only if N=2. I've done a loop from 0 to 100000, and only N=2 creates the segfault.
#include <lapacke.h>
#include <cblas.h>
#include <complex.h>
#include <stdio.h>
#include <stdlib.h>
int main() {
    int64_t ret, N=2;
    float complex querysize;
    ret = LAPACKE_cgesvd_work( LAPACK_COL_MAJOR, 'S', 'S',
                               N, N, NULL, N,
                               NULL, NULL, N, NULL, N,
                               &querysize, -1, NULL );
    printf( "[%ld] %f + i*%f\n", (long)N, creal(querysize), cimag(querysize) );
    return ret;
 This example was compiled thanks to the following command :
 gcc ${your_name}.c -L/opt/intel/oneapi/mkl/2021.4.0/lib/intel64/ -lmkl_gf_lp64 -lmkl_sequential -lmkl_core -pthread -lm -ldl (to correspond with our software).
We observe that this problem doesn't appear in real cases, only with complex ones.
Can you reproduce this bug ?
Tony Delarue
Gennady_F_Intel
The issue would be fixed in the next release/update.
There is a simple workaround for the issue consisting in the replacement of call:
N, N, NULL, N,
&querysize, -1, NULL);
with
float rwork[1];
N, N, NULL, N,
&querysize, -1, rwork );
We will keep this tread updated when the fix would be released.
-Gennady
Gennady_F_Intel
Tony,
before checking the case, I see that you use int64_t type of N. Could you check the problem with int N = 2 instead of int64_t?
TonyDelarue
Same result. Core dump. Here you have the backtrace:
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff1cad2a4 in mkl_lapack_cgesvd_small () from /opt/intel/oneapi/mkl/2021.4.0/lib/intel64/libmkl_core.so.1
(gdb) bt
#0  0x00007ffff1cad2a4 in mkl_lapack_cgesvd_small () from /opt/intel/oneapi/mkl/2021.4.0/lib/intel64/libmkl_core.so.1
#1  0x00007ffff1d0a58a in mkl_lapack_cgesvd () from /opt/intel/oneapi/mkl/2021.4.0/lib/intel64/libmkl_core.so.1
#2  0x00007ffff778f480 in mkl_lapack.cgesvd_ () from /opt/intel/oneapi/mkl/2021.4.0/lib/intel64/libmkl_gf_lp64.so.1
#3  0x00007ffff7953b47 in LAPACKE_cgesvd_work () from /opt/intel/oneapi/mkl/2021.4.0/lib/intel64/libmkl_gf_lp64.so.1
#4  0x00005555555551ef in main () at /home/tdelarue/intel.c:11
Gennady_F_Intel
ok, we will take a look at this case.
Gennady_F_Intel
yes, we confirmed the problem.
Gennady_F_Intel
N, N, NULL, N,
with
float rwork[1];
N, N, NULL, N,
-Gennady
