7287 Discussions
MKL ERROR: Parameter 4 was incorrect on entry to SGESV
Jason_W_2
I am seeing this error above when trying to call the subroutine SGESV. Can someone explain to me what this means. I have also attached the code below.
Jason
    PROGRAM AXIALFD
    implicit none
    INTEGER :: LINEAR, IWHICH,I,J
    REAL :: PE,peinv
    REAL :: DA
    REAL :: NGRID
    REAL :: NRHS = 1
    INTEGER :: LDA,LDB,INFO
    REAL :: DX,dx2
    REAL :: TOL
    REAL :: CHANGE
    REAL :: ITER
    REAL, DIMENSION( 1:10) :: F,C,C11,X
    REAL, DIMENSION(1:10,1:10) :: AA
    REAL, DIMENSION(1:2) :: ANS
    REAL :: RATERXN
    REAL :: DRATE
    REAL :: SUM
    INTEGER,DIMENSION(1:10) :: ipiv
    ! filename axialFD.m
! This code solves the equations for a reactor with
! axial dispersion using the finite difference method.
! a = 1, 2, 3 for planar, cylindrical, and spherical geometry
! If the problem is linear, set linear = 1 to avoid a second iteration.
! set linear to 1 if problem is linear - this avoids one unnecessary iteration
linear = 0
! set the type of reaction rate
iwhich = 2
!set ngrid, Peclet (Pe), and Damkohler (Da) before calling
Pe = 10
Da = 10
ngrid = 10
peinv = 1/Pe;
dx = 1/(ngrid-1);
dx2 = dx*dx;
   LDA = 10
    LDB = 10
! iterate
tol = 1.e-12;
change = 1;
iter=0;
! initial guess
DO i=1,ngrid
c(i) = 0.0;
x(i) = (i-1)/(ngrid-1);
end DO
!if ( change >tol) then
iter=iter+1;
! Set up the matrices
! set the matrices to zero
do i=1,ngrid
f(i) = 0;
do j=1,ngrid
aa(i,j) = 0.;
end do
end do
! set the matrices for the differential equation
do j=2, ngrid-1
ans(1) = c(j)*c(j);
ans(2) = 2*c(j);
raterxn = ans(1);
drate = ans(2);
aa(j,j-1) = peinv + dx/2;
aa(j,j) = -2*peinv - Da*dx2*drate;
aa(j,j+1) = peinv - dx/2;
f(j) = Da*dx2*(raterxn - drate*c(j));
end do
ans(1) = c(1)*c(1);
ans(2) = 2*c(1);
raterxn = ans(1);
drate = ans(2);
aa(1,1) = -2*peinv - 2*dx - Pe*dx2 - Da*dx2*drate;
aa(1,2) = 2*peinv;
f(1) = Da*dx2*(raterxn - drate*c(1)) - 2*dx - dx2*Pe;
ans(1) = c(ngrid)*c(ngrid);
ans(2) = 2*c(ngrid);
raterxn = ans(1);
drate = ans(2);
aa(ngrid,ngrid-1) = 2*peinv;
aa(ngrid,ngrid) = -2*peinv -Da*dx2*drate;
f(ngrid)=Da*dx2*(raterxn - drate*c(ngrid));
do i=1,ngrid
print*,f(i)
end do
print*,''
 DO I = 1,ngrid
PRINT * , (aa(I,J), J=1,ngrid)
END DO
! Solve one iteration.
call sgesv( NGRID, NRHS, AA, lda, ipiv, f,ldb, info )
!call sgesv( n, nrhs, a, lda, ipiv, b, ldb, info )
!c11 = aa/f;
! Calculate the criterion to stop the iterations.
sum=0.;
do i=1,ngrid
sum = sum + abs(c11(i) - c(i));
c(i) = c11(i);
end do
if (linear==1) then ;goto 10
change = sum
end if
!END IF
10 print*, iter
    print*,''
    print*,''
  print*,''
     do i=1,NGRID
   ! print*, F(i)
      end do
END PROGRAM AXIALFD
mecej4
A number of variables that should have been declared INTEGER have been declared REAL. For example, NGRID = 10 is declared and passed as REAL with the value 10.0. The MKL routine expects an INTEGER as the first argument, and interprets the passed value as the integer 1092616192, which MKL notes to be in violation of the requirement that the number of filled rows of A be less or equal to the declared (maximum) number of rows of A.
After you fix the errors related to types of arguments, you have to fix another error: you must define C11 before using it.
Jason_W_2
Thanks much.. it worked perfectly
