MKL Error for DGEMVX (MKL 6.1)
chrisstott
I got this error for my own code, so tried the example code and the error still occurs. I wonder if anyone can help me?
"MKL ERROR : Parameter 6 was incorrect on entry to DGEMV"
command line : dgemvx < dgemvx.d
I used the following makefile for simplicity
LIBPATH="C:Program FilesIntelFortrancompiler80IA32LIB"
test.exe: dgemvx.obj common_func.obj
link /libpath:$(LIBPATH) dgemvx.obj common_func.obj c:mkl_s.lib
dgemvx.obj: dgemvx.f
ifort /c dgemvx.f
common_func.obj: common_func.f
ifort /c common_func.f
Output was:
D G E M V EXAMPLE PROGRAM
m= 4
n= 5
INPUT DATA
M=4 N=5
ALPHA= 0.56 BETA= 1.00
TRANS=T
VECTOR X INCX=-1
1.000 2.000 3.000 4.000
VECTOR Y INCY= 1
1.000 1.000 1.000 1.000 1.000
ARRAY A LDA=4
-1.300 2.300 3.700 4.300 5.900
-1.800 2.800 3.200 4.600 5.700
1.100 2.200 3.000 4.500 5.400
1.900 2.800 3.400 4.200 5.100
OUTPUT DATA
VECTOR Y INCY=**
I've used the equivalent Cblas routine without any trouble from this same library.
Any thoughts would be appreciated,
Chris
(Wouldn't let me post HTML so the formatting is mildly unclear)
Todd_R_Intel
Chris,
Have you filed an issue with IntelPremier support? Parameter 6 of dgemv is of course the leading dimension of the matrix A. Trying the example program is the right thing to do and should work. I built this example on my system using the makefile provided by typing 'nmake lib32 function=dgemv+' at the command line. Perhaps you could give that a try.Off hand,I don't see anything wrong with your code or makefile.
Anyone else having this difficulty?
Todd
Todd_R_Intel
Aha! I had to try your makefile to see it.One should use the cdeclinterface to MKL with theIntel compilers;mkl_c.lib rather than mkl_s.lib.
-Todd
