MKL FEAST EIGEN SOLVER
ctc__tg
I try to use FEAST  to solve sparse Matrix generalized eigen program. Before coding I hope to see some samples.
But I can  not find the samples in MKL/examples/
can you give some samples.
Gennady_F_Intel
please check examples_core_f.zip ( from mkl v.2020.1)  attached to this tread.
mecej4
The samples are supplied packed into Zip archives. Extract the Zip archives to see the files, or list the archive contents using your Zip/Unzip utility.
Gennady_F_Intel
look at <MKROOT>\examples\solvers_eec\source\, or  <MKROOT>\examples\solvers_eef\source\ folders.
ctc__tg
while unzip examples_core_c.zip or examples_core_f.zip, I can only find samples of blas95 and lapack95.
solvers sample cannot be found.
mecej4
In the MKL examples directory, the command
     7z l examples_core_c.zip solverc
showed me 43 files. Similarly, 33 files for examples_core_f.zip
Gennady_F_Intel
ctc__tg
Gennady F.
Thanks!
