MKL_FREEBUFFERS error
Ben_S_
I recently purchased Visual Fortran XE Composer 2013 and got MKL_FREEBUFFERS while compiling my code.
The problem did not occur when I used the earlier Visual Fortran compiler.
Any help would be greatly appreciated.
Zhang_Z_Intel
It has always been MKL_FREE_BUFFERS. Is this what you used?
If this does not solve your problem, would you share a code sample that worked before but failed after the recent upgrade?
SergeyKostrov
Valued Contributor II
>>...I recently purchased Visual Fortran XE Composer 2013 and got MKL_FREEBUFFERS while compiling my code. I assume you're dealing with compilation error ( Not runtime ). Is that correct? In mkl_service.f90 file it is declared as follows: ... INTERFACE SUBROUTINE MKL_FREE_BUFFERS() END END INTERFACE ...
