MKL_FreeBuffers() help
john_curran
Hello
I am using MKL 8.0.1 and programming in C (VS 2003). I want to release memory, and the user notes suggest using MKL_FreeBuffers() or MKL_DISABLE_FAST_MM.
Does anybody know where I can find these? i.e. what libraries or header files do I need to include? At the moment I am always getting linker errors when I try to use one or the other.
JC
dshor1
try adding
extern
"C" void mkl_freebuffers();
and calling it when you need
it worked for me
john_curran
That does the trick!
