MKL Linking issue
augu
Hi
I am new to MKL. I am trying to setup the environment (Visual Studio 2005 + Intel Visual Fortran 10.1 + MKL 10.0) to compile the example program with the FGMRES routines in the Reference Manual.
I followed the guidelines for linking with IVF in the User's Guide:
1.Select Project > Properties > Linker > General.
2.For Additional Library Directories, add the architecture-specific lib folder,
for example, C:Program FilesIntelMKL10.0.xxxia32lib, where xxx is the Intel MKL package number, for instance, "039".
3.Select Project > Properties > Linker > Input.
4.In the Additional Dependencies line, insert mkl_c.lib libguide.lib.
However, I got this when I try to compile the program:
mkl_rci.fi(28) : Warning: Bad # preprocessor line
and a series of unresovled symbol errors when I try to build the program.
Any idea I can get through this?
Thanks in advance.
TimP
This looks like your setup didn't pass an appropriate /Qfpp option to ifort (enable pre-processing during compile).
augu
tim18:
I have put the "/Qfpp" in Project->Properties->Command Line. But I still get the warnings while compiling the program.
The bright side is that after I added the proper include and library directory in Options and Projects properties the program can be built, with the annoying warning though.
